Pulling Rear end and replacing.
Well I've decided to replace my 87 Bronco rearend (8.8,3.55 LS w/ABS) with a Salvage yard unit of the same and was hoping to get some info and advice on pulling it, I've never done this before. Do I remove the parking brake cables from the brake hub or from where it connects to the linkage? It looks like I'll have to disassemble the whole brake shoe system just to get at it and then reassemble it to give them my exchange rear end......is there another way? Are there any other things to be considered in doing this job? Is there a certain order in which I remove and loosen componants? Any help would be great. Thanx
on
Check out this site; http://www.cybrrpartspro.com/Manual%...delLookup.html
If you look up in the brakes section it will explain the procedure for removing the parking brake from the axle. if you look up in the drive train under springs it will give you the torque for the U bolts. Just make sure you support the axle when you remove it. If you drop it one it could kill you. It needs to be supported properly. axle stands on the frame. Lowering one side at a time is the safest. That is what I did.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
