On another note, those of you that did the keypad install, what screw did you use to hold the keypad into the handle. I am worried that mine is working it's way loose.
I just went though the jar of a thousand screws and found one that fit. Origin of the jar of a thousand screws.. When I was a kid, my father used to pick up all of the screws, nuts and bolts that accumulated at the end of our driveway. We were at the low point in the street so it would all end up in the curb in front of the driveway. I noticed that went away in the eighties and nineties as the cars weren't falling apart as much
I should get back in there and secure it a little better at the corners, but I'm the only one who uses it so I'm not too worried about it.
I bought some silicone sealer to seal around the buttons and the lock cylinder. It helps keep the moisture out and makes the buttons a little more sturdy feeling.
