Front license bracket removal
Old Jan 15, 2010 | 09:55 AM
Project F150's Avatar
I've used the search function to try and see if this questions been answered before but I can't find it.
My state doesn't require a front license plate and I want to remove the bracket thats making ugly faces at me. I haven't had a chance to take a real good look at it so I was wondering if anyone has removed it and know what it takes to remove. Any help is appreciated.
08 F150 STX
Old Jan 15, 2010 | 10:05 AM
Elk_Slayer's Avatar
Yep, if it's the plastic one. I just cut the plastic tabs that go between the bumper and valence removed the plate bracket and pushed the tab pieces in towards the slot.
Old Jan 15, 2010 | 10:28 AM
Thanks, I'll give that a shot tonight.
Old Jan 16, 2010 | 01:14 AM
IDNC76's Avatar
you dont have to cut it , you could try and resell it or save it for a rainy day
get a long flat head screw driver, crawl under the truck and find where the 2 tabs are ,inbetween the valance/bumper and pop em out, then lift up and towards the truck
Old Jan 16, 2010 | 01:20 AM
animated_zombie's Avatar
Yep, too easy!
I took mine off just cause I didn't like how it looked (even though I'm supposed to have it... )
Old Jan 16, 2010 | 01:21 AM
rednoved's Avatar
I'm pretty sure mine just popped right off. I took it off about a year and a half ago to clean and polish behind it.
Old Jan 16, 2010 | 11:44 AM
Thanks for the help guys!
Old Jan 16, 2010 | 12:23 PM
Da Wolf's Avatar
Or you can do like I did (accidentally), hook it onto a tree and rip it off. lol
Old Jan 16, 2010 | 08:08 PM
08FX4's Avatar
I started to take mine off but I had to leave it because it had already rubbed through the clear and paint.
Old Jan 18, 2010 | 10:17 AM
I'm going to try taking it off after I get home from work this evening. If I manage to not break it, if someone wants/needs it, they can have it.
Old Jan 18, 2010 | 10:44 AM
rlevi007's Avatar
Yeah. Pretty easy. I went through the lower grille to take mine off because there was a rubber guard in the way from the bottom. There was just enough room for my arms. I think there is still a little scar on my forearm from where I rubbed on the same spot. Well worth it though. It looks so much better sans the license plate mount. Good luck man.
Old Jan 19, 2010 | 07:02 PM
I got under the truck this evening to take a look at how it was attached on the low end and it appears to be made into my valance. I need to take a closer look but I get home so late the sun is mostly down and it's going to have to wait for the weekend to post up the results of my findings.
Old Feb 15, 2011 | 09:40 PM
croot0512's Avatar
Ok, just so I understand... There aren't any holes that removing the front license plate will show and just as long as its a newer vehicle the paint show be fine as well? I wouldn't mind taking mine off.., Give it a cleaner look.
