broken mirror glass replacement
Old Nov 9, 2007 | 03:13 AM
rodneewilson's Avatar
Does anyone have any tips or knowledge on how to replace the mirror glass in the passenger side mirror? Mine are power without heat or blinkers. I only need to replace the mirror glass not the entire mirror assembly,the mirror housing is fine. Darn mailboxes.
Old Nov 9, 2007 | 03:47 AM
Low_e_Red's Avatar
I think you have to replace the entire assembly... Or at least the parts guy told me that.
Old Nov 10, 2007 | 09:32 PM
I really believe you can repalce the glass only. I found a website that sold the glass by itsself. I mean why would someone offer a replacement if you are unable to replace it? Thanks for the reply though.
Old Nov 11, 2007 | 08:16 AM
Jughed's Avatar
A friend of mine at a dealership was able to get me just the glass from Ford. Instructions come with tthe glass. Basically you pop the old one out, then heat up the socket with a heat gun to get the new one in.
Old Nov 12, 2007 | 06:38 PM
Smile
Problem solved. My glass came in today, and after looking at the back side of the glass i could see how it mounted. The only tool I needed was a flat screwdriver, it just pops out and the new one pops in. I didnt heat mine up or anything and didn't have any problems but it's probably not a bad idea to do that. Thanks for the help guys.
Old Nov 20, 2007 | 03:07 AM
memLT-1's Avatar
Just got a passenger side mirror glass today,06 SCrew pwr & heated. With my VIN # the part number was 4L3Z*17K707*DA $24.90 plus tax @ the dealer.
Old Feb 23, 2010 | 12:15 AM
OhioLariat's Avatar
Bringing this back from the grave.
Those of you who have replaced the "glass only," I assume it came with the plastic backing, and the "socket" you speak of is the ball-and-socket pivot point on the back of the mirror (well, molded into the plastic backing the mirror glass" is bonded to)?
I need to pull the glass out of a standard power mirror, and install my signal-mirror glass into it.
BTW, this is for a '99 Lariat. The setup may be different in the '04+?
Andy
Old Mar 21, 2010 | 11:23 PM
dbestfam's Avatar
I also need to replace my passenger side mirror which is shattered. Is the dealer the only way to get a replacement? Will a junkyard mirror be ruined if dismounted?
Old Mar 22, 2010 | 03:05 AM
deerhunter7979's Avatar
Check with Muth for the glass only.
Old Apr 20, 2010 | 05:07 PM
TNoff's Avatar
ok been hunting down parts all day. finally got a decent deal on a mirror glass at the stealership for $21.60 plus tax.
Old Apr 21, 2010 | 11:45 AM
TNoff's Avatar
wow it was a lot easier than I thought. Just take a flathead and pry the mirror off. Push the new mirror back on and that's it.
Old Jul 9, 2010 | 03:11 PM
TheSauce05's Avatar
I know this post is a bit old, but no sense in double posting. I have a 2000 F150 with power mirrors. My passenger side mirror got knocked out and busted and I just need the glass, but in my searching I've found several different types. Some say sport style, some say plain style, and some say sail style. How do I tell which one I need?
Old Jul 10, 2010 | 12:49 AM
FF301's Avatar
i just looked on rockauto.com and they have only 1 style listed and lots in stock just follow there drop down menu it's easy to follow
Old Jul 10, 2010 | 03:02 AM
TheSauce05's Avatar
The motorcraft has about 4 listed. Autozone has 2. Just want to make sure I get the right one.
Old Jan 3, 2012 | 08:00 PM
Kenai555's Avatar
Unhappy Dealership scam
The Dealership around here tried to get me to buy the whole assembly for my 2005 F 150 FX4. They tried tell me that they didn't want to replace the glass because they would break the mechanism and I would have to get a new unit anyway. if you can do it yourself don't go to the dealership to get it done
