4x4 Off Road Decals
Old Mar 23, 2001 | 07:37 PM
DavidF150's Avatar
Post 4x4 Off Road Decals
Someone else may have posted this before but I wanted to enter it in case it helps someone. I got my 1999 150XLT 4x4 without the decals. I bought the decals from the dealer and installed them myself. I had no problem lineing them up but they had lots of bubbles. I panicked and rolled too hard and pricked all the bubbles only to discover the little ones disappeared after a couple days. Now I have too many small holes in them which are only noticable up close. If you do this yourself make sure you only "pop" the big ones and leave the small ones alone. These decals don't remove if you mess up.
Old Mar 26, 2001 | 04:04 PM
Dewayne Fuller's Avatar
Lightbulb
Spray on soapy water before attaching them then work out bubbles - similar to window tint.
Old Mar 27, 2001 | 03:24 PM
AIRBAG's Avatar
Post
But if you do mess up, peeling the stickers off isn't really a big deal. Just start it with your fingernail and peel it off. I peeled mine off after a year or so, i just waxed the area under the decal and now you can't even tell it was there.
Old Mar 27, 2001 | 03:27 PM
fordtec2001's Avatar
Post
tiny bubbles in my wine
Old Mar 28, 2001 | 12:24 AM
stilmore's Avatar
Lightbulb
Also, after using the soapy water and squeegie them out. You can get those little bubbles to dry of faster with a heat gun, or a hair dryer. Those cause them to shrink slightly and pull nice and tight. Just be careful as to not heat them too much... just a little does it.
Old Nov 28, 2001 | 12:55 AM
mudder's Avatar
Wonder how it would look if I removed my decals?
Old Nov 28, 2001 | 04:20 PM
footwart's Avatar
i removed mine useing a hair dryer to warm them a bit. just start on one corner and work your way down. looks alot better.
