Plastic flareside trim
Old Mar 2, 2001 | 01:11 PM
CBechtel's Avatar
Post
Try loosening the inner clips first, the ones you can reach on the underside of the bedrails (I used a pair of needle nose pliers). The outer clips are impossible to reach. Try heating the bedrails with a hair dryer, then pulling up on them. That's the only suggestion I can make. I ended up buying new bedrails for my truck, a styleside. Good luck. If you find a better way, let me know!
Old Mar 2, 2001 | 02:29 PM
SilverFlareSide's Avatar
Question
Let us know what it looks like under there. I have a fiberglass tonneau that doesn't cover the plastic trim on the bed, and i am considering taking them off.
Old Mar 3, 2001 | 12:20 AM
Reamer's Avatar
Question Plastic flareside trim
Is there a special tool requires to get off the plastic bed rails and flareside plastic steps??? I want to get under there for "spring cleaning" and waxing.
'97 flareside lariat No Cracks (door or roof)or rear window leaks with 50K!
Old Mar 3, 2001 | 12:50 AM
Post
I had some body work done on my flareside, and the guy said he would just order new steps because the plastic clips usually broke when they took them off. I'm sure you would be more careful, though, since its your truck.
2000 F-150 XLT
Silver R/C Flareside
Sport Package
4.6L V8
5-Speed
3.55
Flowmaster
A.R.E. "Lowrider" Fiberglass Tonneau
Superchip
2" Drop Shackles
Lightning Front Bumper
Old Mar 3, 2001 | 06:43 PM
Marv1's Avatar
Post
Silver:
After a crash, I had to have new fiberglass bed sides put on. Here's what they looked like during the prep stage. You can see what the top of the fender looks like when the black trim piece is removed...kinda ugly
'99 F150 SC, 4x2, Oxford white, flareside, 5.4,
bodyside mouldings, Snuglid hard tonneau, airbox and fresh air mods.
Duraliner drop-in (gave up on the Penda Nascar). Gibson Supertruck. Ford 2-piece bra. Catch-All floor mats. Image tail light covers. B-Quiet sound dampener in rear of cab. **** pile rug protecting spare tire (Raoul made me enter this)
No door cracks yet at 20K!!!
Old Mar 3, 2001 | 06:51 PM
polarbear's Avatar
Post
yes, those nasty boxside mouldings don't like coming off, and the plastic step pieces i think aren't as bad, but they aren't much $ to replace either.. even when you do take extra care taking the box mouldings off the clips like to break.. that's when they do come off some silly stuff ford does to make a buck..
Old Mar 5, 2001 | 12:14 AM
Winder's Avatar
Post
MarvI: Hey, I was looking at your picture of the Flare side panels that were going to go back on your truck...Are there no "stake-bed" holes at the front end (cab end)?
I was going to drill through the plastic into the stake holes and insert those chrome eyes for extra
ties, but I couldn't seem to locate
any stake bed holes. I guess there are none...?
Winder
2001 Extended Flairside
Old Mar 5, 2001 | 10:48 AM
Marv1's Avatar
Post
Winder:
What you see in the picture is what I know...doesn't look like there are any stake holes there. As you can see, the top of the Flareside fiberglass fender is really ugly when the black part is romoved. Too bad. I think it would take a whole lot of fiberglass skills to make the top smooth.
Old Mar 5, 2001 | 07:44 PM
GIJoeCam's Avatar
Post
THere aren't any stake holes in the flare sides for a couple reasons... first of all, the outer panels are fiberglass... Since they wrap around over the top, they would also need to bear some of the load and would inevitably crack. And besides, you actually plan to {gulp} haul stuff in it?!?! What were you THINKING?!?! Like it's a truck or something.... Sheesh!? Kids today....
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof, built 11/99 picked up 10/00!Clear Corners, Manik Stainless Steel 1-piece brush guard, Custom CB wiring, Uniden PC76-XLW CB radio with K-40 Magna-Mount antenna (for now), 1 set of 165 watt KC Daylighters (for now... more on the way) Custom switch mounting plate and overhead console, Bully Stainless Steel Trailer hitch drawbarw/ 2" stainless steel ball.
List of planned mods: Clear tails, torsion bar tweak, bug deflector, spray in liner, and a tonneau of some sort...
93 Probe GT teal, OE rims painted to match, bone stock drivetrain.
Old Mar 5, 2001 | 10:18 PM
Marv1's Avatar
Post
Here's the rest of the story...the Flareside bed without the fiberglass sides.
Thought you might like to see it.
