CB install pics
Old May 26, 2011 | 04:34 PM
jlyoung08's Avatar
i was wondering why there was soo many wires for your cb then scrolled down and saw the switch panel lol you blew my mind for a sec.it looks good!
Old May 26, 2011 | 04:38 PM
jlyoung08's Avatar
dont mind those wires its since been redone
Old May 27, 2011 | 10:39 AM
1988F150Custom's Avatar
Heres Mine
Old May 27, 2011 | 12:04 PM
jlyoung08's Avatar
that looks good man!
Old Jul 2, 2011 | 01:44 PM
mete's Avatar
Exclamation
Be very careful about putting radios in enclosed areas !! They must be ventilated properly for cooling . My amateur radio will run 100 watts , that heat must be removed or the radio life will be shortened. Transistors don't like heat !
Old Oct 21, 2011 | 05:49 PM
Nail-em's Avatar
COBRA 75 WXST 40-Channel All-in-Handset Mobile CB Radio
This is what I installed last year...the connections and "box" are under my console and all the controls and speaker are on the microphone. When I do not need it I simply remove the microphone and place it in my console. works very good and completly out of site...you can even get a second "box" and move the microphone from one veichle to another!
Andy
http://media.eglobalelectronics.com/.../CBR75WXST.jpg
Old Oct 30, 2011 | 08:57 PM
sands611's Avatar
Above is my recent scanner/CB install
Another View
view of 2 scanner antenas and the middle is CB
Old Nov 1, 2011 | 01:34 PM
me07xlt's Avatar
CB + Console
OK, maybe a little over the top for your needs, but have a look. Might give you some ideas.
There's a few more in my gallery.
Old Nov 3, 2011 | 08:22 PM
fx4210's Avatar
Originally Posted by IDIeselman
We are very limited for install with the center console, So I installed mine in the console itself. I like it and when prying eyes look in to to see what radio I have worth stealing....They see nothing.
I like your set up, i was wondering why you set up your cb at an angle? as i would like to retain the space of my center console, so i was wondering if you think it be possible to set up a clean look like you did while sitting it completely vertically while turning it 90 degrees so the console will run parellel to the drivers legs?
Old Nov 3, 2011 | 09:24 PM
IDIeselman's Avatar
The Magnum is a very large 10 meter radio and had to mounted that way, The Cobra is not stock and has the RFX75 final section added to the rear of the radio. If you are using a stock small chassis radio like a Cobra 29 with only internal mods it will fit just as you would like it to.
Old Nov 4, 2011 | 02:01 PM
fx4210's Avatar
Thanks for the help man
