Factory F150 Audiophile Subwoofer ?
Old Dec 14, 2009 | 10:53 PM
Cuz's Avatar
Cuz
Originally Posted by flareside4life
I went the cheap clean route you're looking at Cuz.
Here's a good place for an OEM 6 disc - http://www.oem-auto-accessory.com/
I'm very happy with them, bought my 6 disc MP3 headunit there.
Bought a Hi-Lo converter, a small Alpine 250 watt amp, and an 8" Punch subwoofer for less than $300. Sounds good, only took a little space under the back seat, and no one knows I've got anything worth stealing. I use the factory door speakers, and building a sealed plywood box didn't take longer than an afternoon.
My next mod is going to be this so I can make use of the empty AUX button on that radio ...
https://www.f150online.com/forums/3804083-post11.html
Good info! I already have the 6disc in dash unit. Just wanting to add a little bass and was hoping I didn't have to add door speakers to make it sound OK.
Old Dec 14, 2009 | 10:54 PM
Cuz's Avatar
Cuz
Originally Posted by smkeater
I have a factory sub and head unit available if your looking for a set
PM sent
Old Dec 15, 2009 | 07:32 PM
Windsor's Avatar
You don't have to do any other mods to add a sub. It's an improvement from what you have now and you can always add other components later when you can afford them. What I've done I sort of did a little at a time, albeit a short period of time. It's by far a competition system, but it puts a smile on my face.
Old Dec 15, 2009 | 11:05 PM
Cuz's Avatar
Cuz
And if my XLT doesn't have a harness already under the carpet in the back under the seat is there some reason I can't get a audio store to run the wiring to a new stock box/amp?
Old Dec 15, 2009 | 11:09 PM
Sundevil2188's Avatar
Why wouldnt you be able to?
Old Dec 16, 2009 | 07:50 AM
smkeater's Avatar
Just sent you a pm
You can get the connectors off ebay. If your handy get the wire diagram and run them yourself to save some $ and time. If not im sure an audi shop would be able to do it
Old Dec 16, 2009 | 09:35 AM
Windsor's Avatar
Not at all. Not having the harness gives you problems with the factory subwoofer. Not to mention, you need a different radio to operate it. I think I mentioned before that with a Metra blue tooth harness you can put any sub/amp combination in the back of your truck, without hacking up your wiring harness. The Saleen sub came with its own wiring harness and the amp was internal.
Old Dec 16, 2009 | 01:56 PM
Just sent you a pm
Not be able to do what? Run wiring for an amp?
Old Dec 16, 2009 | 07:52 PM
Cuz's Avatar
Cuz
SO, if I don't have the audiophile radio then the factory 8" sub won't work on it?
UUGH, I love doing things to my truck but electronics **** me off!
Old Dec 16, 2009 | 09:12 PM
No, you have to have an audiophile head unit with that correct inputs for the sub harness.
By the time you spend all that money on the HU, the harness, and the amp/sub, you could probably have bought a better sounding aftermarket setup.
Old Dec 16, 2009 | 10:41 PM
Cuz's Avatar
Cuz
Thanks SD!
Old Dec 16, 2009 | 11:16 PM
mSaLL150's Avatar
If you are seeking good sound, installing stock equipment is the LAST thing you want to do.
Old Dec 16, 2009 | 11:42 PM
Cuz's Avatar
Cuz
I'm seeking better sound. Not really great sound. I listen to sports radio %75 of the time...
Old Dec 17, 2009 | 08:41 AM
smkeater's Avatar
I have the head unit as well. I agree with the others better sound go aftermarket. The audiophile suited me fine when I had my 06 served its purpose.
Old Dec 21, 2009 | 07:53 AM
NCSU_05_FX4's Avatar
Then why bother wasting time and money to upgrade?
As others said, check your H/U to see if you have a Sub out line. Then check to see if you have the correct wiring.
The stock sub isn't all that great, and if you do end up putting one in it won't be long until you want to swap it out for something else. The stock sub is 8" and rated at 90w, power provided by a small, attached amp.
I dumped all my stock audiophile stuff and replace it with JL pieces. 100x better than stock.
- NCSU
