my console/sub box build
Old Jun 7, 2009 | 11:53 PM
87fiveoh254's Avatar
Looks good so far.
Old Jun 10, 2009 | 05:35 PM
FishSticks's Avatar
Originally Posted by RJaeger
o and did i mention its ported!
side of the box... (its upside down)
inside from top...
again...
from bottom...
You need more port. And I dont know what your tuning freq is but it looks like its gonna be quite high with ~1 cuft per and not a very long port.
Old Jun 10, 2009 | 06:34 PM
RJaeger's Avatar
how big should they be then? each port is 3in wide. as far as the tuning freq any help would be great, i dont know much about that so i was just going to get a friend help with that part
Old Jun 12, 2009 | 06:09 PM
FishSticks's Avatar
Its the sort of thing you do long before you build the box - it has to do with the overall length of the port, and the way that looks youre gonna be using those CVXs as midbass.
It can be remedied, but you have difficult space constraints.
Old Jun 12, 2009 | 06:37 PM
JJDH's Avatar
ports
this link will tell u exactly what u need to know http://mobile.jlaudio.com/support_pages.php?page_id=165
http://www.caraudiohelp.com/subwoofe...e_software.htm
http://www.kicker.com/sites/default/...2006CompVX.pdf
Use 3/4” (1.9cm) or thicker MDF (medium density fiberboard) and seal the joints with silicone. Use the
“template” inside your CompVX’s shipping carton to mark the mounting hole, then cut directly on the
line. These designs need internal bracing. Add triangular bracing between each of the larger
unsupported panels. See Figure 4.
All the cubic feet (L) measurements in this manual include the displacement of the woofer. For the
vented enclosures the displacement of the port must be calculated and added to the internal volume of
the final design. Use the outer dimensions of the port and multiply “X x Y x Z”, convert to cubic feet, for
example the CVX12 vented compact design’s external port dimensions are, using 3/4” (1.9cm) MDF:
[ (2.5” + 1.5” total MDF wall thickness) x (12.5” + 1.5” total MDF wall thickness) x 20”] x (1 ft3 / 1728
in3) = .65 ft3, and add this number to the internal volume of the enclosure, CVX12’s 1.75 ft3 + .65 ft3 =
2.40 ft3. See Figure 5. Due to the necessary length of these ports, you may want to fold the port along
the bottom and back walls. It will be impractical to use round ports for these designs.
Do not install a port opening against a solid surface, such as an internal brace, back-panel or trunk wall,
seat or interior panel of your vehicle. The port opening must remain unobstructed. Use the smallest
dimension of the rectangular port as the minimum amount of space between the port opening and any
solid surface to insure unrestricted airflow
Old Jun 30, 2009 | 08:05 PM
RJaeger's Avatar
little update, everything is ready for fiberglass so once i start on that ill get up more pictures
Old Jul 4, 2009 | 06:05 PM
RJaeger's Avatar
alright finally a good update. i finished up the bin and sanded down the edges then i laid the fleece on it and resined the fleece. waiting for the resin to dry right now so hopefully ill start laying the fiberglass later tonight or tomorrow
Old Jul 4, 2009 | 06:54 PM
JJDH's Avatar
looks good so far... u arent in a hurry are u?lol.
did u check the links for the ports...?
Old Jul 4, 2009 | 07:05 PM
RJaeger's Avatar
trust me man its killing me to have these subs sitting in my room not being used but time to work on it is so hard to find haha yea i looked at the links. i mean i did all the airspace right according to kicker then asked this other guy i know who builds boxes for a living about the size of the ports and he said i should be alright. kinda hard to change it now anyway haha
Old Jul 8, 2009 | 10:51 PM
midwestoffroad's Avatar
cant wait to see the end result
Old Sep 7, 2009 | 09:03 PM
RJaeger's Avatar
alright to start off sorry this took so long to update it now that summer is over im ready to finish it up asap. summer was crazy busy working 2 jobs. the one week i took off work to work on the box i ended up getting shingles! haha the dr didnt even understand why i got them. but its finally all glassed and the bondo is just about done, should be done sometime this week then i can finally paint it and hook it up. keep posted it should be ready very soon!
