Sony ES CDX-M650
I just put this receiver in and it definitely sounds cleaner than the OEM unit. I thought the remote was a bit gimmicky until I used it - it's pretty convenient.
My question for anyone who has this deck(or a deck like this one) is do you get sick of the flashing graphics? It might get a bit old. I suppose I could RTFM but I didn't immediately notice a way to tone the light show down. Thanks
BTW I put 2 pairs of Polk EX572a's in previously. Oh and don't let your dog stand on the mounting kit. It snaps pretty easily until you have it in the dash(the kit, not the dog)
2001 Lariat SC 5.4 4x4 LS ORP Class III Captains seats
Check you owners manual. There is a way to turn off the graphics. I don't remember exactly how, right now. I guess I've gotten used to mine since they don't really bother me.
I like the remote, too. I can keep it within arms reach and not be reaching for the radio or looking away from the road while adjusting it.
2000 F150 XLT 4X4 Off Road 5.4L Reg. Cab 3.55
Performance Enhancemets:
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
All of the above, plus
Sony C7000X HU
Cerwin-Vega SS2502 components(Front)
Blaupunkt PCxp573s(Rear)
Radio-delay mod
(For now)
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
Sony C7000X HU
Radio-delay mod
(For now)
try again
2001 Lariat SC 5.4 4x4 LS ORP Class III 17in wheels Captains seats
Sony ES CDX-M650 2 pr. Polk EX572a
On order: Westin nerf bar, ARE Z series cap, Yakima rack, bedrug
I have the 600. You can turn the graphics off with the menu function. Actually, I wish I had never gotten mine. It skips ridiculously much and I hate it when the cd gets to the end and you can't go to track one, you have to listen to the song or eject the cd. Also, when you get to the no.6 selection an the presets for the radio it goes to FM2 no.1 instead of going to FM1 no.1. Now... i'll get off my soapbox and continue surfing.
1999 White Oxford 4.6L V8 ..Clearcoat..Bugshield..Vent visors..Bedrug..Westin nerf bars..Clear corners..White face gauges..Sony CDX-M600 head unit
I though it did the last track thing to me because I was using burned CDs. What you can do is hold the skip/advance button down to fast-forward to the end of the track, and the player will go back to the 1st track.
I don't know if the skipping is inherant to your deck, or if it's just a fluke. Mine doesn't skip unless I'm on a washboard road going fairly fast. Make sure the back of the unit is supported somehow. If it's not supported and free to vibrate, this is where your skipping is coming from.
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
Sony C7000X HU
Radio-delay mod
(For now)
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
Sony C7000X HU
Radio-delay mod
(For now)
I saw where someone put rubber under the unit to help.
You're right - someone around here took the rubber mount(it's about an inch long and secures the unit into a female connection at the back of the dash)off the back of the OEM unit and put it on the new head unit. Mine threaded onto a bolt sticking out of the back of the OEM unit. I need to remove that bolt and put it on the new unit or just get another one. I could be wrong but the thread size seems to be the same size as an available mounting nut at the back of the Sony unit.
I haven't permanently mounted mine yet because of a broken trim piece(see above). I know I haven't gone bouncing around yet, but no CD skips so far.
I'm really happy with the sound of the unit and the Polks. MUCH better than what came in the truck. Enough clean sound for those inside the truck, anyway.
I just pulled my 750 out at lunch time. you will get used to the light show. Mine just sounded way to processed. and I wasn't impressed at all. The EQ was Ok but nothing great. The DSO total fricked up the sound. The built in crossover was a good effort. I think that they just tried to push too much stuff into it. The sound quality really.....well it sucked. I went back to my CDX-C680 and it sounds so much better. Not a 4volt pre-out, but not perminent either. I will probably end up going with a 910. All in all I'm not that impressed with the whole Xplod series, they are not as clean as the older H/U's IMO. The worst part is that the 750's are an ES model. Supposed to be the best. So much for that. Ok I'll shut up now. Bye.
1997 F150 4.2 4x2 X-CAB Flareside Black
With all of that out of the way, lets get to the good stuff:
STEREO: Special thanks to Josh & Popps @ www.radio-active.org [*]H/Unit SONY Xplod ES CDX-M750[*] F/Speakers Rockford's Fanatic Q Components FNQ2514(THEY SUCK AND ARE NOW GONE)[*] NEW F/speakers are Memphis studios 5X7[*] R/Speakers Rockford's FRC1257 5x7[*] Sub:PheonixGold XS 10" in prefab box under bench seat w/o lift.[*] Memphis Amp ST3004 with front channels running seperates and rear channel running the sub. 5x7 running off H/U
I'm going to change my whole set up.
Under D'Hood:[*] Only a K&N filter.
Its lame, you have to start somewhere right? Trust me, I dream BIG.
On D'Skin:[*] Bug Deflector[*] One Vent Visior, other fell off[*] windshield sticker for www.radio-active.org [*] Hyperwhite headlight bulbs[*] Clear quarter & back glass for an even tint. Thanks Progressive![*] Custom door dings from some A$$HOLE in a parking lot on both sides.
At the moment I am running pretty stock on the outside, but the truck is clean and I have even BIGGER ideas for the outside. SC just got one step closer a lottery so maybe there is still hope.
LINKS:
www.roadarmor.com I said I have big dreams right?
www.nookie.com
LINKS:
www.nookie.com
