Easy Install Question
Old Jun 29, 2000 | 11:28 AM
BadAngler's Avatar
Question Easy Install Question
I just purchased a Poineer DEH-P6000 singe din unit to replace the fac casette player. I've already pulled the fac H/U out using some home made din tools and that was a snap. The question or problem isthe new H/U dosen't have the same type removal system. Rather than the U shapped tools, it uses a coulpe flat pieces that are maybe 4" long and have a 90' bend about an inch from the end. It looks like it'll work in a simmilar fashion but the New H/U dosn't have the tho holes in the front to insert the U tool. I guess my question is am I going to have to remove the Factory bracket and install the new bracket? How much trouble is this gonna be?
Thanks in advance for the help.
  • 1999 Super Cab XLT
  • Windsor 5.4 complete w/ Piston Slap at no extra charge (Thank you very much)
  • 3.55 Ratio L/S
  • White/ Grey interior
    MODS
  • Intake Silencer Removed
  • LoJack Anti-Theft System
  • Bug Deflector
  • Aluminum Tool Box
  • 2 Bull Ring Retractable Tie Down's
  • Bed Mat
  • Class III Receiver Hitch
  • CCA Redfish Decal
  • TTMB Sheepshead Decal
madams@ev1.net
Old Jun 29, 2000 | 03:56 PM
ccla's Avatar
Talking
Maybe I dont understand your question. The original head unit is larger than the new one right? Well then you're gonna need a dash kit and might I also suggest a wiring harness. ( Makes Life a lot easier. ) The radio surround just pops off then you install the dash kit and slide the radio in to that kit. If I misunderstand the question just let me know.
Old Jun 29, 2000 | 09:57 PM
Jason Zaluski's Avatar
Post
BadAngler: Along with your headunit, you'll have to pull out the factory sleeve. The DEH-P6000 comes with the H/U, and a metal sleeve. This sleeve slides into your dash first, and is held in pretty tight. Your H/U slides into that. That is what you use your keys for, to unlock it from that metal piece.
1995 F-150 Regular Cab Flareside w/ 302 V8... Mods: Mass Air, K&N FIPK, Dual Exhaust (no mufflers), Lund Premier Tonneau Cover, Motorsports 9mm Plug Wires, full JL/Kicker/Pioneer system, Autometer 5" tach, Superchip, Precision Gear 3.73s, TD Chrome Diff Cover
Best 1/8th ET: 10.4107 @ 65.9587 MPH
The F-150 Resource Guide
The F-150 Resource Guide-- a site dedicated to 1987 through 1996 F-series trucks.
Old Jun 29, 2000 | 11:31 PM
BadAngler's Avatar
Post
Thanks guys. I got it. I pulled the fac H/U and made a few modifications to the dash kit and it poped right in. The metal sleave around the Pioneer slipped right into the dask kit. I had to bend some tabs on the sleave so it wouldn't pull out but it all went together.
Man I never knew how BAD that Fac H/U sounded!!!
Don't know what I'll do when I replace the speakers
  • 2000 Windsor 5.4 ( slapper replaced)
  • 3.55 Ratio L/S
    MODS
  • Bug Deflector
  • Aluminum Tool Box
  • Bed Mat
  • CCA Redfish Decal
badangler@ev1.net
