CB antenna install
Old Jun 2, 2011 | 05:45 PM
blackspyder's Avatar
I run (well, until the radio is fixed, ran) a 48" Firestick with a custom mount, 4"x1"x1/16" angle about 4" long with a 1/2" hole cut in it, over the bed rail at the first stake pocket so the antenna/coax connection is hidden in the stake pocket and the weight of the antenna sits on the plastic rail cap. I used self tapping screws to secure the 1" side to the bedrail. Brought the coax out through one of the holes in the pocket, over the top of the bed, in through the back door, under the sill plate to the front seat, under the front seat to in front of the center seat where the radio was mounted.
I'll post pics later, gotta find 'em first
Old Jun 4, 2011 | 11:19 PM
fordordie1's Avatar
do show
Old Jun 5, 2011 | 03:14 AM
I gave them their own thread.
Thread link
Old Mar 1, 2012 | 11:51 PM
HamboneFX4's Avatar
Wake Up Old Thread!! haha
Ok I just mounted mine to my toolbox.
How much should it stick up over the cab??
I was considering taking back the 4ft I have now and getting the longer one.
The box is grounded and it is a k40 antenna
Old Mar 22, 2012 | 09:29 AM
C14_Rider's Avatar
The higher up the antenna is the better it will work, now there is a compromise such as hitting bridges and such..
I'm running a 102" stainless whip mounted on the toolbox in the bed and it will hit low bridges and some tree branches......no big deal !! LOL
Old May 11, 2012 | 02:47 PM
Raptor05121's Avatar
Are any of you guys checking your SWR with an antenna tuner?
Old May 14, 2012 | 01:35 PM
C14_Rider's Avatar
I use an analyzer, I'm at 1.2 from the bottom of 10m down below childrens band (CB)...
Old May 30, 2012 | 10:15 PM
KyBoyProud's Avatar
Does anyone have any suggestions about where to install one into a new King Ranch?
Any pictures of a KR CB installation?
Old May 30, 2012 | 10:22 PM
str8t six's Avatar
never
Old Jun 7, 2012 | 06:23 PM
never
I'm just reminiscing of high schoolers who complain of 1-2 mile range and when I hook up an SWR, they're in the 3:1 ratio
Old Jun 8, 2012 | 08:34 AM
dsq3973's Avatar
Always, especially if one of the antennas take a really hard hit from a tree branch or low over hang.
Old Jun 10, 2012 | 01:35 PM
Hespen537's Avatar
Easiest way on something new is a toolbox. Unless you do a magnet mount
Old Jun 10, 2012 | 01:47 PM
str8t six's Avatar
i could get about 9 miles with my old dual 4' antennae setup.
im not sure how far i can get with my whip.
Old Jun 11, 2012 | 11:22 PM
02FORD4X4's Avatar
I have 2 antenna mounted on the bed. one is my cb and the other is my radio antenna. Newb question. What is a SWR? I need to get mine tuned properly(I want more range). Im getting a Couple of 5 ft firestiks here in a month or so to replace my 3 footers.
Old Jun 12, 2012 | 08:09 AM
dsq3973's Avatar
SWR stands for Standing Wave Ratio. Be careful on how tall of an antenna you get because if you go to tall you will be forever hitting branches, drive-through over hangs, and any other low obstruction you can think of that will shorten the life of the antenna.
Here is a pretty good explanation of SWR.
http://searchcio-midmarket.techtarge...ing-wave-ratio
