6.5 speakers in 5x7 wholes in doors
Here's what to do:
Take your 5X7 and trace the outside edge onto 1/4 inch MDF or masonite. (probably masonite because you'll never find the 1/4 MDF) Also mark where the screws go. Then draw the circle for your 6.5 onto the piece of wood. Cut that out and stick it to the door. You will notice that you will need to cut a little metal from the door on the top and bottom of the circle. A jigsaw works fine.
Screw the wood baffle onto the door. Put some silicone or dynamat between the baffle and door. Then screw the speaker in. Your done.
Hope this helped
josh
Hope this helped
josh
