Question for Tim A
Old Apr 19, 2000 | 11:22 AM
Firehawk's Avatar
Question Question for Tim A
Tim, will a 99 or 00 factory cd player hook directly up to a 97 F-150?
If you can't can you get an adapter or harness to make it work?
2000 Ford F-150 Lariat Ext. Cab, Short Bed w/ Off Road Package & 5.4 Triton V-8
Old Apr 25, 2000 | 02:03 PM
Tim A's Avatar
Post
If you have the midline or base radio in your 97 the answer is yes. If you have the premium system in your 97 (which has a CD button on the radio) then no. I don't think an adaptor harness is available.
Also, the 99 radios are bigger than the 97 radios (take up more space inside the dash) so I think you'd have to modify the mounting hardware too.
Old Apr 25, 2000 | 02:07 PM
Tim A's Avatar
Post
Ignore my previous post (I didn't read the question properly). I thought you were talking about the radio itself, not the CD changer.
Yes the CD changer from a 99 can work with a 97 radio, if your 97 radio has a CD button on it. Otherwise, the radio is not setup to work with the factory changer. A harness is available to connect it.
