removal of radio
Old Jan 29, 2007 | 10:23 PM
greatwht's Avatar
removal of radio
ve A 2006 f150 xtra cab, how do i remove the radio??
Old Jan 29, 2007 | 10:25 PM
I believe you need a special din removal tool, or you can improvise with a coat hanger in the shape of a U....
I can describe it better once others verify they still use the din removal tool on the newer HU's
Old Jan 30, 2007 | 07:12 PM
michigunman's Avatar
Nope, no DIN tool required. Once you pop off the trim there are 4 screws holding the radio in. Really easy. Look in the Head Unit and Satelite Radio sections of the forum, there have been a lot of posts fairly recently on this with pictures.
Old Jan 30, 2007 | 09:15 PM
greatwht's Avatar
the trim just pops off?
Old Jan 30, 2007 | 10:04 PM
Yes, assuming it's the same as my 05 there are 4 clips up each side of the trim. You can start at the bottom and pull trim off but you have to pull pretty hard and I didn't have much luck with that. You can use a plastic tool or something like a butter knife to pry on the sides to pop them out as long as you are careful. I bought a plastic tool for $4 that works really well.
Here is a link to one thread I found and I know there are more around. This one is about installing Sirius but it has some pictures that might help.
https://www.f150online.com/forums/sh...d.php?t=260113
