03 screw has no speed sensing volume on Radio????
I'm pretty sure that you have to turn the option on or off... check your manual (and in fact, I think every truck with a premium system comes with a seperate radio manual) and see if you can figure it out. If not, take it down to your stealership and bug your salesman until he gets the answer...
RP
RP
DR7, I think you are correct. Mine does not appear to work either. My 99 had it and it worked. Very noticable to me. I generally used setting 2 or 3. This new truck (03) radio appear to do the same thing as you said. I can adjust, but it has no effect. I drive plenty fast enough to know if it were working or not.
So,
How can we get it to work??? Do we need a sensor to put in there to sense the speed??
I am really ticked at Ford, they up the prices on the trucks but take away features.
Like no courtesy lights on the doors....I had them on my 01 Screw.
No speed sensing volume
no heated mirrors available
etc, etc.
etc, etc.
You are all correct. I have a '03 dual medial HU. This unit does have the Speed sense capability, but as you all have discovered, it does not work. Why?
Well I just found out. After removing the HU, I noticed that the factory wiring harness is missing the speed sensor wire! This appears to be the case in ALL(???) 2003 SCrews?
Interesting that this same HU does work with speed sense in a '01 SCrew....
Who can we complain to????
I just found this out too. I have a "Visteon" branded HU from a 02 Screw and put it in . It looks just like my CD 6 but the CD6 that came with my 03 does not have that feature.
Well guess what? It does not work.
I can't beleive that even the HD does not have them.
I love my Screw but have had it for a month now and here is what I have found that Ford has cut back on compared to our 01 Expy and my former 99 F150...
-Carpet mats are noticilbly thinner, cheaper grade.
-No speed sensing volume option.
-No "Lariat" branded floor mats.
-No courtesy lights on the doors.
-No navigation center as standard on the Lariat, just a compass not a trip feature.
And these are just the things I notice.
