where to place the horns??? for train horn kitt??
alright so i'm aboutto buy a train horn.. but i have no clue where to place the horns... i am going to put the compression tank in my tool box.. but i don't know whether to get the shockers 228vx which has 4 horns or the bandin 400 which has two horns.... please help me decide..... where should place the horns and what setup should i get? i have an 05 f150 .. extended cab 6.5' bed.
i still have my spare tire in. mine is above my exhaust bolted to the bottom of the bed in front of the spare. i had to take one of the horns off to get them above my exhaust pipes but then just put it back on once bolted down. and now that i have the body lift there is a lot more room there.
i can vouch for the horns being fine because i've had mud and water in mine and i just blow it all out, but my compressor is under the hood so it doesn't get too muddy under there.
I'm a the moderator over at www.trainhornforums.com this is the offical forums of hornblaster.com these are my installs i've had on my dodge i know this dosent help much but at www.hornblasters.com they have a install gallery of all different vehicles that you might can get some ideas from.
these are the horns i have had
this is my Kahlenberg D3 ship horn looks small in the picture but is about double the size of a Nathan K3 it weighs about 60Lbs and has 8" diaphragms
its actually rated for ships up to 275 feet
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/WYPHUHfcmfA&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/WYPHUHfcmfA&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
This is the Nathan K3HA I had.
And this if the 2 sets of shockers i had running at 200 psi with 1/2 inch airline and a 1/2 in air valve
