train horns
Originally Posted by steelshot220
thanks what the install like??
All depends on where you want it installled :o
The ones on my G16 took about 30 minutes for the main install and another 30 minutes the next day to install the wireless receiver after I snagged it from the winch
On the other hand, my LC's install took a few weeks cause I had to fabricate a rather large mount
98 Aztek T/A WS7
70 Ram Air IV T/A
97 FZJ80 Locked
00 Lifted G16E
GhettoChopper
i kinda want it just anywhere under the truck screwed into the frame... hooking up the compressor to the battery and a switch and hooking the compressor to the horns is all there is to it right???
Well, you'll want to run a couple of relays...
One for compressor main power that's triggered by the pressure switch (wired to an accessory circuit) and another for the solenoid...
Not complicated by any means, but not as simple as you make it sound
im not a great electrician so it took me around 3 hours but i good one shouldnt take long at all... i just bolted the horns to an exhaust heat sheild (my muffler is dumped) and bolted it back to the underside of the bed. as for the compressor its in the bed tucked into the corner with the hose and wires goin down the drain hole then running along the inside of the frame rail to the battery then a switch on the dash...
take a look at my gallery
I found it to be alot easier than what i was expecting..my horns are in the bed of my truck so i wouldnt get mud in them when i wen offroad..the compressor is behind my seat in my cab. Wiring was pretty simple i got my kit from Hornblasters.com It will have everything that you will need!
On some of those kits,you get what you paid for it. You REALLY need to research this. Try www.airhornsoftexas.com.
I got the NATHANS !! Stilll working on the install I got the horns mounted monday . Compressor and tank mounted yesterday . And , I went out this afternoon and bought the air line and more fittings . I should have it blowin tomorrow. BUT , I wont be finished . I've also got a caboose whistle i'm installing . Which i plan on running with the same Graham White train horn valve . I gonna be bad *** when i get it all set up . It's seems like its taking for ever lol .
