efan wiring for a flex a lite 270
can someone email "detailed" instructions on how to set up my flex a lite 270 fans? the directions are shi* for someone who has never done wiring before. my email addy is pwhitham@orvcomm.com any info would greatly help
Hi.
Please don't take this the wrong way, but efan installs are not generally considered something for a complete auto wiring novice to tackle.
The operation, and more importantly the long-term reliability of the system depends upon best-practice installation & wiring techniques. It's a harsh environment under that hood, and an unreliable install can cause a breakdown in a potentially awkward location, or worse.
If you can swing it, try & find a shop willing to do the work, or a buddy or two familiar with the requirements for this type of install.
Consider, proper fusing, grounding, wire terminations, weather sealing, wire routing, appearance, etc.
It can be daunting for a first-timer. I'm just trying to ensure you get the full benefit from the kit. Ok?
Hope this helps.
Cheers
Bubba
Hope this helps.
Cheers
Bubba
Originally Posted by Bootleg837
Originally Posted by MGDfan
1KK;
Please don't misconstrue my post as a slight on your efforts.
That's a terrific job you did.
Cheers
Bubba
Cheers
Bubba
Later Trev
well i'm getting a speed shop to put them in. is the maintenance on these things just like blown fuses or bad controller/
