'09 Nav install help!! where does the power wire go?
Old Aug 21, 2011 | 11:44 AM
texas_superman's Avatar
Here is my situation.... I have an 09 STX. I am nstaling an AVIC x920bt i bought from a guy from the other forum. It is alrady wired for an 08 so i plugged it up just to see if i could be that lucky. And NO it did not work. That leads me to one question. 1) there are two connectors that come out of the factory unit... will the harness adapter for an 09 have both those plug in, or just one? ? and question number 2) The audio guy i spoke to told me that i would have to run my power wire to the ignition and that the harness adapter doesnt run power. If that is the case where should i run my power? I had a similar situation with my old '06 chevy.
any and all help would be great! Thanks ahead of time!!
--- also after hearing i would have to run my power wire somewhere else, i started to think... will the 08 harness work? it plugs in. I just assumed since the power didnt come on, that it must not work.... but if the power has to run smewhere else, perhaps the harness will work...?? Input anyone?
Picture of the two connectors that came off the factory unit.
Old Aug 21, 2011 | 04:23 PM
dos0711's Avatar
Check Metraonline.com for the adapters you'll need. That made it a breeze!
Old Aug 21, 2011 | 04:33 PM
thaks for the reply, but i got excited and couldnt wait to order anything, so... i removed my coin holder (non 4wd) and found a hot wire there that i used, and worked great!
Old Aug 21, 2011 | 04:37 PM
dos0711's Avatar
I wanted to be able to easily put my factory stuff back in if I needed to.
Old Aug 21, 2011 | 04:45 PM
Me too. the wire i cut will not affect me replacing the oem radio. the factory harness is unaffected. The unit was already wired with an '08 harness that i just used. The only isue i had was the power problem.
Not the best pic, and the Metra Kit is okay, not great, but thhis is a major upgrade for me, so i may look at the other kits later on.
Old Oct 17, 2011 | 05:49 PM
mseller's Avatar
i am looking to do this as well...where did you get your power wire from?
Old Oct 18, 2011 | 08:53 PM
The little coin holder to the left (non 4wd) has the power wire for the 4wd switch. I spliced Into it.
Old Oct 18, 2011 | 10:03 PM
mseller's Avatar
hmm i got the 4wd so that won't work for me...i'll have to look for another wire...so which color did you need to connect off your harness? im assuming yellow or red off the metra 5520 is what you were using...http://www.sonicelectronix.com/item_...mpaign=froogle
Old Oct 18, 2011 | 11:44 PM
Yu will have to ask around on that one. When I bought mine the previous owner had it wired to an '08 harness, and luckily it worked on mine, minus the power wire. That's the only thing I had to find to splice into for mine. Sorry I can't be any more help.
