I need the Eclipse AVN Navi DVD
Old Apr 18, 2007 | 08:09 AM
WBSCLariat's Avatar
You don't think I've tried a simple disk copy first? Everytime with the disk copy any dvd copy program I used would fail after copying the dual layer image from the original and right at the start of the burning operation. Even tried saving the image first to hard drive and it would still fail when you tried to burn the image. Results were the same with Nero and Roxio. Both are the latest releases. The above method works successfully. Have you tried what you are suggesting with an Eclipse Nav disk and been successful?
The most logical reason I've been given for the copy a disk failure is that when copying disks the disk formats must be compatible. The Roxio help instructions bear this out.
Looking at the Roxio help you will see that a DVD RAM is not compatible to a DVD +R DL. Here's what it is compatible.
Source DISK Compatible Target
DVD-RAM to DVD-R***, DVD+R***, DVD-RW (quick erased), DVD-RW (full-erased), DVD+RW, DVD-RAM
*** The target disc will not be appendable.
Old Apr 25, 2007 | 07:18 AM
gogocheez's Avatar
sorry to get off your topic, but i need help from WBSC...need to tell my av guy this morning what dash kit you used for your avn6600,, please help.. he has my unit sitting out from my dash about a 1/4 inch, i cant live with that..he's blaming it on the kit i got from crutchfield..thanks..
Old Apr 27, 2007 | 12:52 AM
NOLES187's Avatar
I have the eclipse avn 5500, and I had to flip the brackets inside the dash that holds the head unit in around so that it would sit flush...keep playing with it, you will get it!
Old Jun 11, 2014 | 07:01 AM
bdcar's Avatar
Originally Posted by NOLES187
As posted in an earlier thread someone broke into my truck and stole all of my cd/dvds...
https://www.f150online.com/forums/sh...d.php?t=277613
the only one I really cared about was the Eclipse AVN5500 Navi Disc....does anyone know if they can burn me a copy, or if I have to contact eclipse?
Thanks for all the input guys...such a great site!
Hello
I do have navigation disk.
Please take a look
coronabd.blogspot.com
All the navigation map disk downloadable and for you all.
You can message me in
facebook.com/navigationdisk
2014 Navigation A22,A23,A24,A25,D53: ND3N-D53、ND3N-W53、NDCT-W53E、ND3A-W54A、 ND3T-D54、ND3T-W54、NDCN-D54、NDCN-W54、NDCT-W54E、ND3T-W55、NDCN-D55、 NDCN-W55、NDDA-W55、ND3T-W56、NDDA-W56、NDDN-W56
Old Jun 11, 2014 | 07:09 AM
bdcar's Avatar
i do have the disk
please contact via my gmail :
bdcar.bangladesh@gmail.com
regards
marshal
