Eclipse Nav system "factory sub don't work"
Old Mar 7, 2006 | 11:56 PM
F150Truck'in's Avatar
Originally Posted by nothinbutaford
I've got 25 30D's in stock and they all have the preout harness only the older 30D's didn't have it. I haven't got any 50D's in stock right now but I'll double check to make sure it has a preamp. Plus you said you had a sub level control is that on the info/settings screen along with wallpaper and guidetone.
yes, its there, any chance you may have a preout harness laying around??
Old Mar 8, 2006 | 12:01 AM
nothinbutaford's Avatar
I'll take a look to see if I have an older harness to use on an install tommorro on a lexus rx330 cause I don't need the preamp for this car.
Old Mar 8, 2006 | 12:12 AM
thanks nothinbutaford, let me know what you want for it with shipping and all, i'll send you the money paypal or how ever you want it handled....if you look a www.eclipse-nav.com this is the 30D and in the install, this is what harness I have now.....
thanks again
must have removed the install manual, i don't see it now....
Old Mar 8, 2006 | 11:59 AM
tlytle01's Avatar
The Metra connector is part number 70-5521, it is on a national backorder
The AVN 50D does have sub control.
Old Mar 8, 2006 | 07:09 PM
nothinbutaford, check your Private Messages, I keep forgeting we have that now...
Old Mar 8, 2006 | 07:20 PM
try a 70-5522 its the sub plug only the 70-5520 is the main harness and the 70-5521 is both.
Old Mar 11, 2006 | 01:59 AM
Rockpick's Avatar
Moderator &
Don't forget to add a 1.5kohm resistor in line with the blue remote turn on. This will prevent turn on pop noise. Also the 50d I believe does not have sub volume control so the sub may overpower the rest of the system. Its an easy fix, just get a low pass filter with an input gain adjustment and that will take care of it. It will also make the factory sub sound better (less boomy) crossed over.
I really hate to sound stupid here but, can you put that in terms I can put to use in my truck? LOL
Mine has thumped since day one... it's an annoyance but, not something that really drives me batty. If this is a simple fix and it's as simple as plugging something in, in-line, I'd be ready to do it in a heartbeat.
Crutchfield customer service had forwarded me an email on how to make a little resistor thingamajig to prevent it from happening but, after looking at it a bit, having a couple of flashbacks to College Physics II where we talked about circuits, crying in the corner because of said flashbacks, and then deciding not to do it because I wasn't comfortable building such a circuit, I allowed it to 'thump' and I haven't worried about it since.
Thanks for any help you can give me... I really appreciate it!!
RP
Old Mar 11, 2006 | 12:28 PM
very very simple don't put much analysis to it.
On your harness coming out of the eclipse there is a blue wire with a white stripe on it. That wire is conected to the blue wire on the metra harness.
Cut those 2 wires apart from each other.
Get a 1.5K ohm resistor (rad shack is fine).
Connect 1 side of the resistor to the blue&white wire from the clipse.
Connect the other side of the resistor to the blue wire from the metra harness.
DONE
For the tech reason for that, the ford amp turns on with a 5volt signal from the radio. The voltage from the eclipse(or any aftermarket) is 12volts. By putting that resistor in line in turns the voltage down to 5 where it needs to be eliminating(mostly) the thump you here.
Old Mar 11, 2006 | 08:04 PM
Rockpick's Avatar
Moderator &
Gosh... that sounds too easy. To my recollection, my 5435 has two blue/white wires. One of them had a spade connector with it (out of the box) that had a safety boot (plastic) on it. I'm almost certain that I wired mine such that both blue/whites tie to the harness blue/white (so, two from the radio to one on the harness). Should I drop one of them and just tape it off and stick with one with the 1.5 ohm resistor? I assume this is a simple solder? splice connectors?
Thanks man!
Old Mar 12, 2006 | 09:36 PM
YES I typically use the one in the main harness, but either will work both are identical outputs.
YES I usually use butt connectors or crimp caps, it's an interior, non stress connection.
Old Mar 12, 2006 | 10:24 PM
Rockpick's Avatar
Moderator &
Thanks man! I'm going to try to give this a whirl sometime this week. I'll let you know how it goes. Thanks again!!
I hit you with some WELL DESERVED Reputation points!
Old Mar 16, 2006 | 06:30 PM
f150mil's Avatar
Stearing wheel buttons
so after installing the new HU did the stearing columns work? I'm wiht you on getting somethign differnt but I paied extra for Audiphile and hate to waste it. i want the stearing controls to work.
Old Mar 16, 2006 | 09:28 PM
you can use a piece from pac its called swix, it will work with any remote ready radio.
Old Mar 16, 2006 | 09:48 PM
Rockpick's Avatar
Moderator &
AVN 5435 installed here... my steering wheel controls work.
Like NBAF mentioned, you're going to want to get a SWI-ECL device... The -ECL is specifically made for the ECLIPSE units and is exactly what I have.
Third product down on the page...
Old Mar 18, 2006 | 02:18 PM
bobfawcett's Avatar
Sub plug
The harness needed to operate the sub is a Metra 70-5521 entire harness or 70-5522 for just the sub plug.
