Lincoln Blackwood & Mark LT
Gas mileage
Old Sep 25, 2011 | 09:45 PM
Jim Blackwood's Avatar
Gas mileage
Anybody had a drop in economy and found a fix for it? My Blackwood dropped to 14/15 mpg where it was up around 19 and nothing I've tried has made a dent in it. I'd love to hear some new suggestions.
JB
Old Sep 27, 2011 | 01:22 PM
mon74's Avatar
I was getting really crappy mileage, but turned up to be the gas quality here in Mexico, was using the 93 octanes (supposedly) premium, but the cheaper 89 magna helped a lot...
Went from 8.3 mpg in the city to 12-13 and 12 mpg in highway to 17-18, my truck is now clocking 34,500 kilometers.
Hope you sort it out.
Ramon S.
Old Sep 27, 2011 | 01:30 PM
azmidget91's Avatar
Front O2 sensors and spark plugs
Old Sep 27, 2011 | 02:46 PM
executor485's Avatar
Air filter makes a big difference, assuming you've changed it out recently?
Old Sep 29, 2011 | 06:04 PM
Filters, plugs, O2 sensors (all 4), injectors, coils, cleaned the MAF hot wire... Seems like I tried one or 2 other things...
JB
Old Sep 29, 2011 | 06:37 PM
ak_cowboy's Avatar
You sure your not running E85?
Old Sep 29, 2011 | 06:46 PM
azmidget91's Avatar
Tire pressure is another thing, I always run 40 psi in light truck tires
Old Oct 6, 2011 | 11:00 AM
Not running E85, and tire pressure would account for at most 1/2 to 1 mpg. When the truck had 40K miles on it, it regularly got 19 mpg highway and for the last couple of years it hasn't done better than 14. That's a 5 mpg drop and better than 25% decrease.
JB
Old Oct 6, 2011 | 03:48 PM
Spark plug wires, clogged fuel filter, possibly a bad fuel pump?
Old Oct 9, 2011 | 10:36 AM
All replaced recently. Except plug wires, it's COP.
JB
Old Sep 30, 2012 | 10:50 AM
ronnshf's Avatar
Late to the party. :-) Temperature sensor CPU input lost??? Engine would run cold parameters. your neighbor, ron :-)
Old Oct 1, 2012 | 01:25 PM
Thanks Ron, good suggestion. Would that cause it to set a code or turn on the check engine light? I have neither.
Old Oct 1, 2012 | 06:03 PM
bigblackmachine's Avatar
Try a gallon of Toluene in the gas tank mixed with 4 gallons of gas (ratio); it's a super easy & inexpensive way to clean the whole fuel system, especially including fuel injectors. Why pay the costly dealership price for a fuel system cleaning. This does the exact same thing. Don't spill any on your paint! Can be bought at any paint store. This has worked for me on several occasions, & even gives my cars/truck more pep & better gas mileage if I keep my foot out of it.
Old Oct 3, 2012 | 01:35 PM
beechkid's Avatar
25 Year Member
This will work, but may I suggest, Marvel Mystery Oil....It has much of the same but it also will lubricate the fuel injectors......
