What does a green hue on sparks plugs mean?
Old Dec 1, 2002 | 06:43 PM
detail's Avatar
What gives...some of mine have it. No deposits, just a little green.
Old Dec 1, 2002 | 07:12 PM
Don's Bolt's Avatar
If it is more of a brownish color it is OK, I am not sure about green, any pics?
Old Dec 1, 2002 | 07:13 PM
99svtlightning's Avatar
In most cases it means you are getting a little antifreeze in there.....However you can also get that if recently spilled antifreeze in the motor and it seeped into the plug holes.
Old Dec 1, 2002 | 07:19 PM
LIGHTNINROD's Avatar
I did a 'google' search and couldn't find any reference to a "green color". Blue could be overheating? Have you used any fuel additives or it could be something in your normal gas--for the winter?
Dan
Old Dec 1, 2002 | 07:39 PM
JBLsilver01's Avatar
I asked Sal about my plugs - some were a little green - he says sometimes it means a lean condition, or not the right heat range for a certain application.
Old Dec 1, 2002 | 07:41 PM
rscoleman's Avatar
A green hue or green 'specks' is a sign of detonation. If it's antifreeze (which I doubt) than you have a cracked head or block or both.
Old Dec 1, 2002 | 07:48 PM
Here's a decent explanation:
Spark Plug Condition
Old Dec 2, 2002 | 02:38 AM
detail's Avatar
well i did get one run down the track w/ detonation on my race tune. then went 4 gallons of 114 octane LEADED race fuel in with my 15 gals of 93 to cure that problem. think that was it??
Old Dec 2, 2002 | 06:47 AM
Rob_02Lightning's Avatar
It's detonation , and it only takes one run, this is mine after one 1/4 mile run with a clogged fuel filter.
Sal saw them and agreed the green meant lean. I changed the fuel filter, threw those schitty TR-6's away, put in Denso IT-22's took off my 2-3 lb upper pulley and ran a 12.8 1st time out with filter, chip, + 4lb lower, Can't wait til spring to put the upper back on, change the filter again and go get me a low to mid 12 sec run.
If I can find my old post I'll send you the link where we all talk about the green plugs.
Old Dec 2, 2002 | 07:44 AM
Flying Mofo's Avatar
Banned
You used leaded race gas in an unleaded vehicle?
Are you running cats or not? May have plugged them.
Old Dec 2, 2002 | 09:28 AM
jaymz's Avatar
Mold?
Old Dec 2, 2002 | 10:57 AM
brap's Avatar
I did this once by accident and it caused my truck to shutdown at the 1/8 both times, you cats and 02 sensors dont like it much. My truck has run fine ever since I got the leaded gas out of it though. And my plugs looked normal, not green
