Shot a rod through my oil pan....
hey Jeff
It's obvious that you like to call people names which in a sense shows lack of maturity. How old are you? You don't live at home by chance? With time you will learn that there are other opinions than just yours..
Liar this , liar that. So if calling names dismisses my degree of maturity, you must be on a 3rd grade level at best.
With time you will learn that there are other opinions than just yours..[/
Take your own advice and realize when you come on here constantly complaining about JDM, then ownly people who care are the newbies who don' t know better, which is believe is a direct affect on Jim's buisness. If he wanted to be a *****, i'm sure he could make more of a deal about it. It's water under the bridge guy. Deal with it how you must but no one want's to hear it anymore. Take Jim's advice and call him up and talk to him one on one, or better yet, take a ride over there. I hate to have to turn into an ******* at points on this board, but enough is enough. GET OVER IT!!!
tallimeca you still have not answer my questions...Is there something you don't understand about the word liar? Since you like to quote allot I'm sure you can PROVE all the times I have called someone a name...Since we are talking about proof did you read those messages that I got from your tuner that supposedly are bogus? I'm constantly bashing your tuner huh? Once again you seem to be proficient at the cpu so do a
and look at 1300+ posts. If you think that I'm the only person that this ever has happened to then you need to talk to someone(father) about it because your living in fantasyland
if you are so bright...
I will not respond to anything your write back , nor will I bother to even read this thread anymore. The more I read this, the stupider I feel. It's rotting my brain.
Tallimeca do these mods look familiar?
12 Second Tallimeca
12.9 @106.9 at full trim on F1's!!!!!!
here's the slip
60' 2.07
1/8 8.41
mph 86.50
1/4 12.99
mph 106.90
mods:
JDM Chip
JDM Filter & Intake
JDM breather
JDM Boost Bypass
JDM electric fan kit
Cobra R water pump
JDM 2lb pulley
TR6's
Accufab throttle body
Factory Tech Valve body
Bell tech 2" Drop Shakles
Manual Switch Intercooler Pump Mod
Do you remember that little button?
You are so transparent it's laughable.. I must be a genius that I could have figured out who your tuner was...Actually anyone who has read your posts could have figured that out..
So please don't read this or reply to it because as you stated"The more I read this, the stupider I feel. It's rotting my brain." I think in fact the real truth is the more you post here the stupider you look....or is it dumb?
12 Second Tallimeca
here's the slip
60' 2.07
1/8 8.41
mph 86.50
1/4 12.99
mph 106.90
mods:
JDM Chip
JDM Filter & Intake
JDM breather
JDM Boost Bypass
Cobra R water pump
JDM 2lb pulley
TR6's
Justin I will but don't you also think it's time for... nah forget it...I would have moved on days ago if it were not for someone here who likes to call people names... But Justin you are right and this will be behind us... Thanks
FYI
Those 8,000 miles with a 6LBer have been very hard miles. I try and go to the track as much as possible. I don't count how many times I have made a quarter mile pass but it is in the triple digit range. I drive my truck hard because that is what I bought it for. I didn't buy it for it to sit in a garage all week to drive it to church on Sunday. I just don't have that kind of money to do something like that. And if I did I probably would have bought a GNX or a CobraR and I still would drive the Lightning everyday. I wasn't trying to start any trouble with my post just sticking up for the guys who run 6LBers and I am sure there are quite a few of us.
And if and when my motor goes I will be buying a tuner motor most likely unless money is extremely tight. I may even buy one before that. Thanks, -Mat-
Don't forget the muffler bearings and blinker fluid.
