Another Problem!
Old Oct 13, 2002 | 08:51 PM
LightningTuner's Avatar
Tim, sounds to me like one of three things, that I've seen from experiance with the same problem...
1- Bad 2nd gear shift solenoid
2- Bad valve body (acutally if if were the VB, it would still shift, just not have the proper firmness)
3- Bad mechanical diode
When my 01 was a week old I was racing a Viper and the trans hit 2nd really hard then it would just freewheel unless I let off the gas after that. The dealer replaced the trans, and when the old unit got back to the plant Gregg said my diode was misbuilt and missing a few one way rollers.
Old Oct 13, 2002 | 09:13 PM
Tim Cowley's Avatar
I was hoping it was an easy solution. Can I cry agian about pulling that tranny? I put it in there by myself it was a monster feat! My truck is telling me that it does not want to leave Texas, I was planning on leaving for Virginia and I have had 2 problems in one week! I guess Mr. Gregg Evans will give me my solution about 2am. I will let yall know.
Tim
Old Oct 13, 2002 | 10:13 PM
Factory_Tech's Avatar
Well, I'm stumped. Is it shifting into second with manual? It doesn't have a mechanical diode, it's got one of the 45 element sprags, so I really doubt that's your problem. Did you try the TPS thing?
G
Old Oct 13, 2002 | 10:18 PM
If you eleminate all the other possiblilities, I will of course rebuild it, but I hate to have you take it out again etc... let me look at what could have gone wrong...and keep trying the other things. Have your dealer give you a code on what caused the OD light to flash, that will help me a lot.
G
Old Oct 13, 2002 | 10:40 PM
Tim Cowley's Avatar
I am going to check the TPS volts tommorrow. I have not taken it to a dealer. I have a freind with a code analizer or whatever you call it, its the same as thay use. And no codes showed up just one and that was my boost dump. Since I killed the truck the light quit flashing. I read on a search about a flight recorder , have no idea. I asked if we could drive it while it was connected would any codes show up that would not show up with it parked. I will check it out and see. I will run every test we can before I pull that tranny agian. Its hard me to belive its inside, yours is the best in the buisness! Thanks Gregg will let ya know.
Old Oct 14, 2002 | 09:29 AM
Silver-Bolt's Avatar
Tim,
No codes were shown when my friends TPS failed. I thought my volt meter was bad since it was reading 0.0. Swaped the throttle body and re-checked. It then showd .97 and has been running and shifting great since.
Old Oct 14, 2002 | 09:36 AM
Marc Carpenter's Avatar
Pull the pan. remove the 1 to 2 upshift plunger, polish it, reinstall it and see what happens.
Marc
