Another Problem!
Old Oct 13, 2002 | 12:59 PM
Tim Cowley's Avatar
Unhappy Another Problem!
Well I put Toulene in my tank and has been running like a beast! Today at WOT the motor winding out without it going into gear. It like fell on its face. So now the RPMs go real high without it changing into 2nd gear. I have to let up on the pedal to get it to change. Anyone with a suggestion? My tranny has 2000 miles on it and I have the stock converter in. Could this be a tranny problem? If so I will ask the Expert. Thanks Tim
Old Oct 13, 2002 | 01:29 PM
Silver_2000's Avatar
Tim
Sounds crazy BUT check your blower pulley...
Dont ask me how I know
Doug
Old Oct 13, 2002 | 01:31 PM
Tim Cowley's Avatar
I have heard it slip , but me will check it out! Thanks Doug. I checked it out , it looks fine. When I changed to a #4 from a #2 I used the same belt. I had to break of that peice on the tention pulley so it would fit. Its feels tight. I will drive it to see if I hear the belt slipping. These trucks screem in cooler weather, on this stock block I be scared of my JDM chip!
Old Oct 13, 2002 | 01:58 PM
Tim Cowley's Avatar
I checked on the pulley it don't seems to be slipping. With the chip in it changed into 2nd gear at 3500 rpms, and it was hard! I took the chip out and it still did not want to change. Not much of a differance. So I will ask Gregg. I hope its simple fix!
Old Oct 13, 2002 | 02:01 PM
clonetek's Avatar
Originally posted by Silver_2000_!
Tim
Doug
you know i gotta ask..... how do you know this... lol
Old Oct 13, 2002 | 03:13 PM
Mine started acting weird one day.. I was convinced the trans was gone.. The real issue was the lower pulley had broken from the hub and was freewheeling...
With NO boost the truck acts strange...
Start the truck open the hood and see if the blower is turning ... Mine wasnt
Doug
Old Oct 13, 2002 | 05:06 PM
clonetek's Avatar
Old Oct 13, 2002 | 05:29 PM
J.D. Blackwell's Avatar
Re: Another Problem!
Well, lets start eliminating the last thing you done. Burn that tank of gas and put pump gas back in it and try it.
2nd, I know you put new plugs in your truck recently. What plugs did you put back in and what is the gap?
Also, did you let your tranny temp get warmed up before the incident happened???
Sometimes the problem is something simple.
Old Oct 13, 2002 | 05:41 PM
Tim Cowley's Avatar
Well J.D the plugs and motor is running real good. I just drove it agian and it don't like to shift into 2nd gear. If I let the pedal off it sometimes catches. I can't drive it like that ,I was headed to Rodney's but it too hard to get it to change. If theres a problem with the tranny will it show up in the codes in the computer? If so I will get it ran tommorrow.It still has Toulene in the tank, 1/2 tank to gal.
Old Oct 13, 2002 | 05:56 PM
jeff2001silver's Avatar
Mine did the exact same thing at about 12,000 miles. Dealer replaced the trans. under warranty, no issues after that.
Old Oct 13, 2002 | 06:10 PM
Fast Gator's Avatar
sounds like a tranny, hope your local dealer can warranty it
Old Oct 13, 2002 | 06:45 PM
Tim Cowley's Avatar
Its a Monster Box!
Old Oct 13, 2002 | 07:20 PM
Silver-Bolt's Avatar
Check you voltage at the TPS. If it is only shifting when you let off the throttle this is a likely suspect. Just had it happen to friends truck. His TPS went bad. He had the exact same symptoms. Checked the voltage and it was 0.0. Changed the TPS and set the voltage and it was back to shifting normal.
Old Oct 13, 2002 | 07:26 PM
Spanky99L's Avatar
Doug
like this:
Happened to me the other day. Doug is right no boost SUX
Old Oct 13, 2002 | 08:43 PM
Tim Cowley's Avatar
Did you have to take the pulley off to find this out? I ran the codes a miniute ago and no codes were found. Would that TPS voltage show up? I also noticed that I had my overdrive flashing. Could my stock converter be bad? Im going to do a search now, done tried greggs site could not find anything.Thanks
