This can't be normal? Is it? (pic)
Old Sep 14, 2002 | 09:29 PM
captainoblivious's Avatar
Originally posted by LightningTuner
Hey Vinnie, if you are using a breather cap, go to a Sears Hardware and pick up a 7/16" ball bearing for a buck or so. Then pull the rubber elbow off the PCV valve, stuff the ball bearing into the elbow, and put it all back together. That will solve 99% of the oil for practically no money.
Sal, I don't understand how that would help??? Could you explain a little bit more.
Vin - now you know why the other night I was showing you what I was trying.
And no the thing your pointing to is not the PCV valve. That has a plastic hose that connects to and goes over the driverside valve cover, but there is no PCV valve there. The valve is located on the drivers side, look at your breather cap and go back from there, you will see a rubber gromet on the valve cover with a rubber elbow on top of it. Pull that up and you will see PCV valve
Old Sep 14, 2002 | 09:58 PM
VINNIE's Avatar
Pete,
That is one of the reasons I checked today.I wanted to see if I had any oil in there.
VINNIE
Old Sep 14, 2002 | 10:00 PM
VINNIE's Avatar
Re: Hey Vinnie
Originally posted by BLOWN HARD
What are you planning on doing w/ your stock TB? If you want to sell it, let me know what you want for it. Thanks,
Dave
Dave,
Sorry ,I keep all the stuff I take off.Just in case I ever sell the truck(to buy A new one of course).The basement is getting real full.
VINNIE
Old Sep 14, 2002 | 10:01 PM
BLOWN HARD's Avatar
VINNIE,
Hey VINNIE,
What are you planning on doing with your stock TB??? If you want to sell it cheap let me know!
Dave
Old Sep 14, 2002 | 10:25 PM
device manager's Avatar
Billet optima battery cover
Who sells the Billet optima battery cover?
Old Sep 14, 2002 | 10:47 PM
VINNIE's Avatar
Re: Billet optima battery cover
http://www.eddiemarine.com/cart/deta...38&CategoryID=
Old Sep 14, 2002 | 11:14 PM
BLOWN HARD's Avatar
That's cool Vinnie... i understand completely! Thanks anyway!
Dave
Old Sep 14, 2002 | 11:57 PM
tallimeca's Avatar
hey Vin
Mine looked the same way when i changed it over up to FFW in NH. I brought it over to show everyone but i guess you weren't there at the time, you would have be prepared for it. Isn't it amazing how much stuff is caked on the back of those butterflies???
Old Sep 15, 2002 | 12:06 PM
Sal, I don't understand how that would help??? Could you explain a little bit more...
TTT
Old Sep 15, 2002 | 12:52 PM
P38 Lightning's Avatar
Vinnie, The oil is coming up from your passenger side head, through the back of the intake and then towards the front into the intake plenum then to the plastic tube that runs down to the drivers side valve cover. I know this is exactly the opposite of what it looks like but this is true. Check the threads for the fix. The Hausfeld filter really does work, since installing this myslef it have stopped the oil from at least getting to the throttle plate or the plenum itself.
Old Sep 15, 2002 | 01:02 PM
LIGHTNINROD's Avatar
TTT
The 7/16" ball bearing effectively plugs the line from the PCV to the intake. It eliminates the PCV from 'working'. Note: Sal said "if you have a breather cap.".
Dan
Old Sep 15, 2002 | 01:16 PM
Dan
Thanks.
Not sure I want it to stop working though
Old Sep 15, 2002 | 01:50 PM
lightningsc's Avatar
throttle body
Dave i just installed my Babolt single blade throttle body this week and i have my stock one for sell. it has only 4000 miles on it and is in perfect shape. i want 50.00 plus shipping. let me know. thanks gary
