F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Lightning (https://www.f150online.com/forums/lightning-50/)
-   -   This can't be normal? Is it? (pic) (https://www.f150online.com/forums/lightning/90397-cant-normal-pic.html)
VINNIE Sep 14, 2002 03:50 PM
Putting on my S/B throttle body and WOW,when I took off the OEM T/B there was oil everywhere.
I know a lot of guys are putting in filters for this,but how come the breather cap filter does not help more?
Is a little oil normal? Or should it be completely dry.
https://www.f150online.com/galleries...1645-30915.jpg
Back of the OEM throttle body
https://www.f150online.com/galleries...1645-30916.jpg
Inside the intake tube
https://www.f150online.com/galleries...1645-30917.jpg
blowntruck Sep 14, 2002 04:01 PM
Holy crap...:(
kidtriton Sep 14, 2002 04:05 PM
Looks normal for about any car/truck. You should see the inside of the intake of a SOHC explorer with anywhere over 10k miles on it.
VINNIE Sep 14, 2002 04:07 PM
Thanks,I was getting a little nervous.
VINNIE
BTW- I also added a polished billet optima battery holder and a JL box for the shaker hood.
https://www.f150online.com/galleries...1645-30918.jpg
https://www.f150online.com/galleries...1645-30920.jpg
Spike Engineering Sep 14, 2002 04:18 PM
Imagine how much oil has clogged up the fins on your intercooler.
:eek:
VINNIE Sep 14, 2002 04:29 PM
:eek:
I was thinking the same thing.Think I should pull the blower off and see.Also what would be the best method of cleaning?
VINNIE
Fast Gator Sep 14, 2002 04:35 PM
No oil in my intake when I replaced my t/b with the polished BaBolt T/B:D
mecca Sep 14, 2002 04:39 PM
Hey VINNE. New stuff looks sweet! You should give Paul a call over at REM. Get one of his oil seporator kits. It'll solve that problem.
REM - 954 917 9200
-Mike
VINNIE Sep 14, 2002 04:43 PM
REM - 954 917 9200
-Mike
Thanks.
I guess i will be calling him monday morning.
VINNIE
LightningTuner Sep 14, 2002 04:44 PM
Hey Vinnie, if you are using a breather cap, go to a Sears Hardware and pick up a 7/16" ball bearing for a buck or so. Then pull the rubber elbow off the PCV valve, stuff the ball bearing into the elbow, and put it all back together. That will solve 99% of the oil for practically no money. :)
VINNIE Sep 14, 2002 05:16 PM
Sal,
Thanks alot.I am using a breather cap and the oil looks like it is coming up through the pcv valve.I had thought of plugging it up but did not think I could.
Thanks again
VINNIE
Here is were the oil is coming from
https://www.f150online.com/galleries...1645-30935.jpg
Lightningfun Sep 14, 2002 07:11 PM
As far as cleaning....what I do to all my vehicles is take a can of brake cleaner and spray it into the intake and TB (intake boot removed) and maybe use a toothbrush to do a little scrubbing. Don't use the whole can but spray it in there fairly good. Put it back together and start the truck...it will stumble a bit and you may need to give it gas but it does wonders and can even clean up a rough idle. I have never had a problem doing this on my cars and it seems to work.
Tom
DaveRed99 Sep 14, 2002 07:22 PM
good IDEA !!!!!
:eek:
The Orphaner Sep 14, 2002 09:18 PM
Just say no to brake cleaner!
Dont use brake cleaner on anything other than rotors...use throttle body cleaner. Brake cleaner will eat off the coatings of the TB.
BLOWN HARD Sep 14, 2002 09:29 PM
Hey Vinnie
What are you planning on doing w/ your stock TB? If you want to sell it, let me know what you want for it. Thanks,
Dave
