Plug question
Old Aug 21, 2002 | 05:38 PM
easterisland's Avatar
Question Plug question
Is this what a Denso plug is supposed to look like after a couple of thousand miles?
That's right, I put the Tr-6's back in at a .040 gap...
Old Aug 21, 2002 | 06:00 PM
RTKILLA's Avatar
I'm putting my old plugs back in also. I drove around on the IT 24's all day yesterday and by the end on the day 300 miles, they are starting to foul out already. the IT24's must be way to cold for my truck I guess, but I'm going back to TR6's also, atleast until I spray the truck.
what pulley's are you running on your truck? I think your the same as me with a 4lb lower and 2lb upper right?
Old Aug 21, 2002 | 06:11 PM
6lb lower and 100 shot of nitrous. Going to 150 and metco upper. It has been running a little rough, I thought it was the plugs(cold,) I'm glad I got those waste of money plugs out as soon as I did.
Did you see the insulator? That's right it broke right off into the combustion chamber. The iridium electrode is bent a little and the outer tip has been burnt off a little...
Old Aug 21, 2002 | 10:34 PM
has anyone else had this happen to a denso plug?
Old Aug 21, 2002 | 10:38 PM
LightningTuner's Avatar
The green color and speckles is a classic sign of way too lean. Sorry Easter, but don't be blaming the plug. The way that electrode is burned, the green discoloration, and the missing insulator ceramic means your very lean, and detonating pretty hard.
Old Aug 21, 2002 | 10:39 PM
SLVRLTNG's Avatar
I had a problem with my IT 24's too. After a few hundred miles I had a miss, I changed them out for NGK BR7EF's.. That's waaay too much money to waste on a set of plugs that were recommended for my mods... ....JR
Old Aug 21, 2002 | 10:49 PM
LTNBOLT's Avatar
Cool
Thank God your motor got out of that one alive. It's not always a happy ending when a plug comes apart.
Old Aug 21, 2002 | 10:50 PM
I have had a mechanic ride with me and they hear no detonation. The auto tap shows no misfires and that I am way rich. The other plugs look good. This plug was taken from the #6 cylinder. I have them gapped at .032. They are IT-24's
If detonation is audible then I have no detonation. If it is silent I just don't know.
Old Aug 21, 2002 | 10:54 PM
You might have a problem with that one cylinder. Autotap is not going to show you accurate A/F, and the misfire monitor in the factory PCM is a joke. I've had cars with multiple dead cylinders when I worked at the dealer show no misfires.
Old Aug 21, 2002 | 11:02 PM
okay thanks. I'll check the compression and stuff tomorrow.
Old Aug 21, 2002 | 11:06 PM
JohnnyLightning's Avatar
No doubt you had some detonation to do that to the it24. ive ran upwards of 24# of boost with no problems with them. however i do not reccomend the 24's for daily drivers. the plug is a very cold plug and will start to foul out with constant low rpm drives. the 22's are reccomended up to 18# of boost from the testing ive done with these plugs...JL
Old Aug 21, 2002 | 11:20 PM
This is one of the TR-6's I replaced the Densos with this afternoon. I guess it is a cylinder problem...Only #6 has this problem...
Old Aug 22, 2002 | 05:55 AM
Fast Gator's Avatar
YIPES
Good thing you caught this
Old Aug 22, 2002 | 07:15 AM
Silver_2000's Avatar
WOW !!!
Old Aug 22, 2002 | 08:03 AM
PFA's Avatar
PFA
WOW! Now this is getting a little technicle for me...what do you do about something like this? If it's mainly just one cyl. doing this?
