Torque Converters on the 4R100
Old Jul 28, 2002 | 12:10 PM
ken800's Avatar
Okay, I searched and found a bunch of threads on aftermarket torque converters, but wanted to get a comprehensive thread going. Hopefully factory tech and some of the other tuners will chime in here...
1) What is the stock stall speed of the stock converter?
2) How much higher over stock would you want to go over stock to still be an every day driver including stop and go traffic?
3) The TQ locks up around 40mph or so, according to PI's website. Not the same as stall... Will an aftermarket torque converter with the same stall speed as stock lock at the same speed? Is the lockup a function of stall? I.e. higher stall means higher speed before lockup?
4) There are 2 alternatives (at least) to the stock converter. PI states that the stock converter has a torque multiplier of 2.53:1 vs stock of 1.93:1. Does anyone know what art carr's rating is? I assume the multiplier and moving the launch higher into the rpm band for more horses/torque are the main performance benefits of an aftermarket unit.
5) Is there a tranny cooler on the stock truck? If so, can it be improved, or should one go aftermarket? How hight would you push the stall on a daily driver before messing with additional cooling for the tranny?
Thanks for any and all responses.
Ken
Old Jul 29, 2002 | 02:46 AM
SVTMoonshine's Avatar
I second this question.... Anyone?
Old Jul 29, 2002 | 04:27 AM
DR.D's Avatar
you might do better to post in the Factory Tech Forum in supporting vendors at NLOC. He's a knowledgeable 4r100 trans guy.
http://www.nloc.net/forum/forumdispl...s=&forumid=452
Old Jul 29, 2002 | 09:21 AM
Silver-Bolt's Avatar
I will fill in what I know (which isn't much). The lock-up is controlled by the computer. It can be adjusted up or down. It has no bearing on the stall. If you add a stall converter it will generate more heat. Heat is a killer of automatics. L's do come from the factory with and external cooler. I personally would not run a stall converter without additional cooling. Better be safe than sorry. $150 cooler or $2000 for trans rebuild?
Old Jul 29, 2002 | 10:50 AM
ken800's Avatar
Thanks, I'll post it over there... I am sure there are a bunch of folks that would like the answers to these questions...
Ken
Old Jul 29, 2002 | 01:37 PM
easterisland's Avatar
after the stall my tranny runs pretty hot...I'm going to add a cooler this week.
Old Jul 29, 2002 | 10:28 PM
bobcmt's Avatar
Witha 2400 stall and an aluminum pan, my tranny temp is always at least 20-50 F lower than water temp. Takes a long time to get above 120, the highest I have seen is 160F. No temp increase at the drag strip!
Local shop re-worked stock converter for 2400 rpm stall for only a few hundred dollars, installed price less than cost of PI Convertor and reduced 60' and ET by 0.15 sec.
Old Jul 29, 2002 | 10:49 PM
whitetoast11's Avatar
Just a questiong,, does anyone have any links to tranny coolers other then larger pans etc??
~Toast
Old Jul 29, 2002 | 10:54 PM
Silver_2000's Avatar
I have watched the tranny temps with Auto tap
With the Tranny cooler running through the radiator and through the external cooler the temp is typically within 20 degrees of the engine temp. Unless the aluminum pan has fins that help or something...
Am I missing something ?
Doug
Old Jul 29, 2002 | 11:46 PM
ken800's Avatar
Not just looking for a higher stall, but a higher torque multiplier, too. What is the stock stall?
Old Jul 30, 2002 | 12:11 AM
The highest temp I've seen on mine is almost 200* With Auto Tap
2400 Art Carr converter 4x4 pan
The return lines are close to the long tubes and cats, maybe that is why they are hot...
Old Aug 6, 2002 | 11:24 AM
Well, to give some feedback on what I found out on the Art Carr torque converter. My tranny temps are way too hot so I installed an additional transmission cooler with a fan. Tranny temps stayed approx. the same. Jim@JDM datalogged my truck and the Art Carr torque converter stalls at 3800 not the 2400 I purchased. I think that when the stock converter goes back in this week it will all be better. Yes, I'm pretty mad that I have to R&R the tranny again.
In short don't purchase an Art Carr converter. I bought mine form mark@lightningforceperformance.com
Old Aug 6, 2002 | 07:19 PM
ken800's Avatar
what is the stock stall speed?
Old Aug 6, 2002 | 08:05 PM
JeffsLightning's Avatar
I know of another guy who had a very similiar problem with AC. Then sent him another converter and now he says it's right. Took another tranny pull and some time but he finally got in back together.
Old Aug 6, 2002 | 08:27 PM
Rusty's Avatar
i heard 1800 is stock stall. i would like to know the answers for your questions too.
