Torque Converters on the 4R100
Old Aug 6, 2002 | 10:30 PM
ken800's Avatar
I have posted this on NLOC and in the Factory Tech forum... Hoping to get some answers to the questions as I know a lot of you guys would like to know them as well.
Basically it boils down to this: After lockup, I feel like my truck sucks. I would like to see it lock up at a higer speed (mph) so I can continue to benefit from torque multiplication. I think it locks now around 40 or so, not too sure.
If I put in a converter that locks just a little higher than stock -- say 2100 or so, what will it do? I know lockup and stall are separate things, but is one a function of the other?
Old Aug 7, 2002 | 10:29 AM
easterisland's Avatar
Originally posted by JeffsLightning
I know of another guy who had a very similiar problem with AC. Then sent him another converter and now he says it's right. Took another tranny pull and some time but he finally got in back together.
I'm not going to take the chance that it will be right. I'm reinstalling the stock one and if I decide to go with an aftermarket one later on it will be a PI. I don't think I should be a guinea pig. They sold me a 2400 stall and it is a 3800 stall. I guess if they paid for my time to R&R the tranny it would be a different story. This is a $200-$300 job at most shops each time the tranny is removed.
Old Aug 7, 2002 | 02:53 PM
Silver-Bolt's Avatar
Lock up can be tuned through a chip. Any mph you desire.
Old Aug 7, 2002 | 05:26 PM
ken800's Avatar
Silver-
My understanding was that tweaking the speed at which lockup occurs is a function of line pressure. If that is indeed the case, I do not want my chip messing with line pressures. I don't know the answer to this one for sure, just what I have heard.
Old Aug 7, 2002 | 11:21 PM
bobcmt's Avatar
Lock-up is controlled by chip, not line pressure; can be set at any speed. Super Chips (SC) used to eliminate lock-up until 4th gear. SC and JDM have been locking them up sooner on some programs to keep from wasting HP and ET's seem to have improved. Yes, I used to feel like mine bogged some when lock-up occurred about time of 1-2 shift. Current chip has lock-up occurring at ~1000 ft; this phantom shift drops rpm 200-300 rpm.
When lockup occurs it negates slippage of higher stall converers. Stall and lock-up are independent. Stock stall is ~1800 rpm. My 2400 rpm stall works great on the street, I even pull a car on trailer occasionally without problem. Finned pan, stock cooler, and 160 thermostat keep tranny at ~150F in steady 90-100F air temp highway or intown driving. Tranny is more like 120-150 or less at track and have not seen any heat-up during burn-outs. Stage at 1,500-1,700 rpm. Staging at higher rpm does not improve my times, actually run about same 60' times at 1,000 rpm. For me, hard launch comes from converter flash on take-off, not loaded stall.
Engine temp is exactly 100F above air temp at 70 - 100F and tranny temp 20-30 less than engine temp when fully stabilized.
My poor boy altered stock converter was done locally for a price too low for you to believe. It has now increased to ~$300 exchange with a billet front plate. Saw ~0.15 sec improvement at all points on the track. Not selling anything, just sharing.
Old Aug 7, 2002 | 11:44 PM
ken800's Avatar
I thought there was more torque available before lockup, but then that is why I am asking... Something like a 2:1 torque multiplication vs. 1:1 after lockup? How could locking sooner create a better ET? I do appreciate the education as always.
thanks
ken
