Ring and Pinion install info/specs?
Old Aug 7, 2002 | 05:45 PM
SVTMoonshine's Avatar
Help installing Ring and Pinion. install info/specs?
Can anyone point me to a comprehensive Ring and Pinion install advise? I plan on putting mine in tomorrow morning. I need to know:
Slap?
Pinion depth?
torque settings?
Any help is appreciated. This will be my first time with a seasoned mechanic standing behind me.
This will be on a 99 L putting in 373's
Old Aug 7, 2002 | 06:23 PM
firefighter106's Avatar
Try this site drivetraindirect.com
It has some nice info.
Old Aug 7, 2002 | 07:30 PM
Rumba83's Avatar
For the pinion depth you really ought to use the depth guage setup, as for as backlash, i think the spec is 7-15 thousandths, personally i like to set mine up tight, can't remember the turning torque off hand, i've done enough that i set that by feel. If you have access to the ford special tools it ought to be pretty straightforward.
Old Aug 8, 2002 | 12:21 AM
I don't know what "depth guage setup" is?
Do you mean whatever stock shims set the pinion at?
10 hrs before I start....
