What the Roush springs drop looks like...
Old May 20, 2002 | 01:07 AM
thepawn's Avatar
Had them earlier in the week....2" around.
Daniel
Old May 20, 2002 | 01:27 AM
CrazyFoo's Avatar
only 2", it sure does look lower than that! But it looks GREAT!
Old May 20, 2002 | 03:28 AM
StrikesTwice's Avatar
Geez, only a 2" drop did THAT? Man, looks good, how do they handle, and how much did you pay?
Old May 20, 2002 | 09:40 AM
Full Auto's Avatar
Man thats low.
Looks awesome.
Old May 20, 2002 | 09:47 AM
thepawn's Avatar
The kit is rated at 3/3.5" for a regular F150, but that means 2" for a Lightning.
I can't say how the springs would handle by themselves, I did a 3--2-1 punch for my suspension upgrade.
Roush springs : ~485
Hotchkis Sways: ~535
HAL QA1 Shocks:~680
(I also have truck-traks and a panhard-bar)
The truck handles like a DREAM...fantastic...the body roll is minimal, no unpredictability over rough surfaces, minimal wiggling...
I can't wait to race it next weekend. (SCCA Solo2 event)
Daniel
Old May 20, 2002 | 10:01 AM
Spike Engineering's Avatar
Looks great and I'm glad you like the way it handles! Now, all you need to do is fine tune the tire pressures. I was able to dial in the shocks quickly but the tires took time. Are you running the stock pads still?
Spike
Old May 20, 2002 | 10:08 AM
thepawn's Avatar
I'm currently running NAPA Cermix, but they're just about past the half-way point on being worn-out. The Hawk's should be here tomorrow or wednesday according to the place that I ordered them from.
So far, I'm running 40psi the tires... I think I may stiffen up the back a little, I'm still running it a 4, I'm goign to try 6 and see how I like it. What pressures you currently running at?
Daniel
Old May 20, 2002 | 10:38 AM
Try 34 to 36 psi on the street (cold-without sun on them). When you get your pads on, test (in a safe area with lots of runout) straight line braking and turn-in. If you're carrying good speed, you'll get an idea (REAL QUICK) whether or not you have corner entry oversteer or understeer. BTW, don't try trailbraking. After a couple turns, you'll have a better idea of what adjustments you need to make to tire pressures. Adjust the rear only in 2 psi increments (up or down) and the change will be dramatic (you'll be surprised how much 2 psi will affect handling).
I run my shocks (street) at 9 front, 6 rear. I only change the front for the track and leave the rear at 6. You can try 5 or 6, but I wouldn't go any higher.
I've talked with several people now who have run the NAPA ceramix pads and they wear very quickly.
G
Old May 20, 2002 | 04:18 PM
thepawn's Avatar
Ive discovered that. (Cermix wear quick). They're made by Raybestos....
My rear stock pads are finally going (36k mi), and my Ceramix are going with them too... I only got ~12k-ish miles of the Ceramix compared to the 24k I got of stock pads with much the same style of driving time.
I'll try playing around with the pressures... I didn't think that on street tires there would be a large effect, then again, I've never quite run "street" tires as good as these on any previous vehicle I've owned, lol.
Daniel
Old May 20, 2002 | 05:15 PM
sixpipes's Avatar
Daniel,
I think you're going to really like it. A very well balanced set up for a bolt-on kit.
Old May 22, 2002 | 02:54 AM
Z28KLR's Avatar
Could you post the measurement's of the Roush kit, center cap to wheel well. Thanks
Old May 22, 2002 | 09:55 AM
thepawn's Avatar
My truck was level before the install (heavy *** bedlid I guess?) and showed 18.5" (or there abouts) all the way around. After the springs settled, I'm showing about 16.5" all the way around...
Daniel
