What did I do wrong?
Old May 13, 2002 | 01:23 AM
Guapo's Avatar
Well, after much toil, I found that Zaino isn't as easy to apply/remove than they'd have you believe... but after letting it dry for about 16 hours, and wiping it down, there was still some sort of residue on it. I sprayed it with some water, and wiped it down again, and it looks pretty good. Just removed the 2nd coat of Z5, but I can't look for streaks, because the sun was down. Will probably need to wipe it with a wet towel again.
I didn't know my reflection could show up so well on a truck. The first coat didn't seem to do a thing for the swirl marks, though.
Somehow, my truck managed to come from the dealer with swirls all over the hood. Bah.
Old May 13, 2002 | 01:33 AM
ricekicker's Avatar
Registered User
You really don't need to let it dry that long...in the Florida sun I can put it on and wipe if off in 5 min.
I also found out to NEVER let it sit overnight because during the night the air cools and condenses leaving a wet film on the truck and making it impossible to get off. Also be sure to always use a clean side of the towel. And don't use too much!
I have been using Zaino but i ordered some Cherry Wet Wax to test it out...might switch if it is easier and as shiny.
Good luck on your truck
Old May 13, 2002 | 04:02 AM
Ak.Silver2K's Avatar
Bummer
Sorry you're having such a tough time. Try some wet cherry. Its easy to use and it looks great. I can't imagine getting a much better shine.
Mark
