Gas Mileage
Old May 6, 2002 | 02:12 PM
EXCITED's Avatar
mileage
be glad you don't have the 10% ethanol added as we do in the midwest=less gas mileage, the alchohal burns off quiker.
Old May 6, 2002 | 02:17 PM
Spike Engineering's Avatar
Re: But are there any "mods" that can be done to improve gas mileage.
Originally posted by LIGHTNINROD
What Jason said.
Also: be sure your F1s are checked 'cold'(I wait overnight) for 32 psi, your front end is alighned correctly, your air filter(K&N 'type') is clean, your plugs are properly gapped(with no misfires), your front wheel bearings are properly greased(and adjusted), remove 'unnecessary'(hitch, spare, jack) weight, press the gas pedal down as though there were an egg underneath it(and you didn't want to make a mess ), get a tonneau cover, if you must use the a/c--use it instead of driving with the windows down---and last but not least..............draft behind an 18-wheeler whenever possible .
Dan
Better yet:
Remove engine, transmission and driveshaft, and gas tank.
Add tow hooks to front or coast downhill. Howl or scream out the window to simulate supercharger.
Be careful when trying to turn. Power steering is just your arms, but it gets easier the steeping and longer the hill. On the other hand, power brakes are just your legs so try not to make steering to easy (i.e. big long hills).
Old May 6, 2002 | 03:30 PM
thepawn's Avatar
Smile
