Truk Tracks
Old May 4, 2002 | 08:25 AM
SLVRLTNG's Avatar
Truk Tracks
Think I am gonna buy a set of Jay's Truk Tracks. Looking for some real world opinions and/or improvements in 60ft times...Will be running on my F1's for a while.
TIA......JR
Old May 4, 2002 | 11:26 AM
StruckBy99's Avatar
I have a set of Lakewood slapper bars on mine which are similar to the Truk Tracks.
Last night i ran 1.74 60ft times on E.T. streets.
My only mods are JDM chip, 4pound pulley, and open filter.
Hope this helps.
Jason
Old May 4, 2002 | 11:31 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Wink
inbox
Old May 4, 2002 | 12:06 PM
EXCITED's Avatar
curious
I am curious also ,do they keep the rearend from moving/ do they keep the tension off of the driveshaft and u joints? going to order some monday if they protect my driveline?
Old May 4, 2002 | 12:12 PM
Chikenears's Avatar
Hope this helps.
Jason
Do you have a part number for the Lakewood bars? Did you get them from Summit or Jegs?
Tim
Old May 4, 2002 | 01:02 PM
SLVRLTNG's Avatar
Tim,
you got mail....JR
Old May 4, 2002 | 01:59 PM
StruckBy99's Avatar
I got my Lakewoods from Jegs for $99 shipped.
Part number 21910 is for F150's
Some people were talking about cheap u-bolts holding them to the leaf springs, but mine came with grade 8 bolts and 3/8 inch steel plates that bolt together.
On the track you can feel these lifting the truck when the tires hook, which happens more often now.
Jason
Old May 4, 2002 | 02:10 PM
SLVRLTNG's Avatar
Both Summit and Jegs are out of stock.
part numbers have changed too:
summit: LAK-21715 90.30 out of stock til May 30
jegs: 620-21715 99.99 out of stock til May 10.
I just got off the phone with both, part numbers I had were no good anymore. .....JR
Old May 4, 2002 | 03:50 PM
CHIKIN1's Avatar
I've got'em...I love them...i think my 60' dropped .05 right off the bat...The Truck reacts much faster in my opinion and now I don't worry as much about breaking the driveshaft!!!
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
424HP/528ft.lbs @ Normal Temp. w/o N2O
JL Logocaps w/Keychain
JL 3# Lower Pulley
Sean Hyland 2# Upper Pulley
JDM Cold Air
JDM Boost Bypass
JDM/Accufab Throttle Body
JDM Longtubes w/ Silver-Bullet cat-back
JDM Cobra R pump
JDM Eletric Fan
JDM 2” Drop Shackles
PSP 4-Way Autologic Chip ( Tow, Street,Track, N20 )
PSP FactoryTech Valvebody
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Nitrous Express 50-150 Kit ( Can’t decide which jets to use )
NGK / TR6’s ( .040gap )
Hoosier DOT’s 28 x 10 x 16
Old May 4, 2002 | 04:00 PM
J15BIG's Avatar
are the truck tracks worth the $180 extra as opposed to the lakewoods? in your opinion of course
Old May 4, 2002 | 07:16 PM
Jay Lincoln's Avatar
3/8" grade 8 bolt+ 5000 lb. truck+ 450 lbs of torque=disaster.
I'm not doing this to sell traction bars. I don't want to see anyone tear up their trucks. If a front bolt breaks, you can pogostick the traction bar, which will rip the rear-end out of the truck.
Keep your eye on those bolts. They will probably stretch and get loose before they break. Make sure they stay tight. If they do get loose, they have stretched, and should be replaced.
The Lakewood bars were originally desighned for a stock F-150.
Old May 4, 2002 | 07:55 PM
Fast Gator's Avatar
AMEN
Old May 4, 2002 | 08:03 PM
Fast Gator, what can I say. I've been there and done that.
I guess I should thank Lakewood for putting me in the traction bar business
Old May 4, 2002 | 09:06 PM
StruckBy99's Avatar
Jay
Are you trying to tell me that you broke a 3/8 gr.8 bolt?
I'm not buying it.
A grade 8 bolt (1/4" to 1 1/2" dia.) has a proof stress of 120,000psi and a tensile strength of 150,000 psi.
MORE than enough, even in a 3/8 dia.
Almost every single suspension bolt is a grade 8 or better.
I realize your trying to sell a product, but i think you are using scare tactics. --Dont buy those they'll break-- I think people need to get away from "It costs more, it must be better"
I'll be sure to let everyone know if one of my -weak- gr8 bolts break.
Jason
Old May 4, 2002 | 09:33 PM
JeffsLightning's Avatar
Jason when/if you break those bolts I'll give you a ride home...lol
