"service engine soon" light came on...help!!!
Old Apr 16, 2002 | 10:01 PM
lihtning's Avatar
As the subject says, this light came on. I'm guessing it's because of the mods I just did, but maybe someone can shed some light on the subject. I just installed (on my 2000 L) a 90mm mass air, JDM cold air kit, and an SVO throttle body. I do not have a chip yet (as it is in the mail to PSP as we speak) and I'm just wondering how to cure the problem. Disconnecting the battery works for a short period of time, but then it comes back on. The truck still seems to run fine, but this #*&#%&* light keeps coming on. Thanks in advance for any help.
Old Apr 16, 2002 | 10:07 PM
Don's Bolt's Avatar
90 mm mass air setting off a lean code, if you drive mellow till you get the chip you will be ok.
Old Apr 16, 2002 | 10:11 PM
lihtning's Avatar
Don
that was a quick response! Thanks for your help today and over the past few weeks. By the way, are you 100% positive that is what it is, not that I'm doubting you, but I have heard that it could be so many things? Regardless, you've been a big help!
Old Apr 16, 2002 | 10:50 PM
Struck in AZ's Avatar
lihtning,
Yank off the 90mm and air filter and put your stock airbox back on (should take about 5 minutes to do) and drive around for a while. I can guarantee that the SES light does not come on.
Dan
Old Apr 16, 2002 | 11:35 PM
awhittle's Avatar
If that doesen't work...Auto-zone has code readers
Andy
