Temperature display says "ICE"
Old Mar 7, 2002 | 12:20 PM
LAST50's Avatar
Has anyone noticed their temperature display on the overhead console? Mine normally give the temperature and the direction you're facing. However, some mornings it says "ICE". Has anyone else seen this?
Old Mar 7, 2002 | 12:23 PM
ema100c's Avatar
mine too
Mine flashes between "ice" and the temperature once it gets below 37 degrees or so.
Old Mar 7, 2002 | 12:28 PM
la23602's Avatar
I have seen this also when the temp. is freezing
or below, the display says ice. Sometimes there is
ice on the windshield.
Old Mar 7, 2002 | 12:57 PM
snoopy's Avatar
It's in the owner's manual. Icing can occur on overpasses and some roadways when the temp drops below 38F.
Old Mar 7, 2002 | 02:12 PM
PhillipSVT's Avatar
It must since moiture or something. One night it was about 20* and no ICE warning, but I have seen it say ICE at around 33* one night.
Old Mar 7, 2002 | 02:14 PM
LAST50's Avatar
Snoopy - We're almost neighbors. I live in Westmont. CHeck out midwestfords in my sig.
Old Mar 7, 2002 | 04:37 PM
BlackLight's Avatar
Red face Don't listen to bad advice from clueless people
That is just crazy.
What it really means is that you should cool down your drink...
snoopy's Avatar
Hiya LAST50. I know Westmont well. My wife and I sometimes hang out at Tracy's on 55th to catch the Indiana basketball games with the rest of the alumni. Go Hoosiers!
About the "ICE" thing: see page 79 in your owners manual. "If the outside temperature falls below 3C (38F), the display will alternate from "ICE" to the outside temperature at a two second rate for one minute." Mine has been doing it about every morning since I bought it. Tomorrow + 60F!
Old Mar 7, 2002 | 04:45 PM
LAST50's Avatar
Well, being a Purdue grad, I won't be going there for any IU games.
Old Mar 7, 2002 | 07:33 PM
MiamiWhiteSVT-L's Avatar
HEHEHEHE............mine did that once too....just once! And I'm in Miami!! See, sometimes it does get cold here!! Well, ok, it gets cold here about once or twice per year, but it was still cold!!
JC
Old Mar 7, 2002 | 08:17 PM
Hooch's Avatar
Question What makes "ICE" flash?
On 2-27-02 I drove to Nashville and back seeing a low of 16 F on the plateau and a high of 27 F, but I never saw the "ICE" flash up.
Anyone?
Old Mar 7, 2002 | 08:45 PM
WCFan's Avatar
Talking
Want to have some fun with you temperature gauge remove it from the inter-fender location and mount it into the air cleaner and you will know your intake charge temperature before the supercharger. Just for kicks.
Old Mar 7, 2002 | 10:28 PM
jrjen2's Avatar
Mine has not had the "ICE" flash at me in a while. The reason for that is because we have not gotten up to freezing since about October. Just after Christmas, the temperature in interior Alaska was about negative 42 degrees! AT that temperature, the gauge flashes, "IT'S *******ING COLD!" If you don't believe me, come on up next January and see for yourself.
Old Mar 7, 2002 | 10:38 PM
z96Cobra's Avatar
Re: What makes "ICE" flash?
Anyone?
That's because it was already below freezing and you should know that there could/should be ice on the road. It flashes "ICE" at 37 so you realize that overpasses/bridges could be freezing.
Roger
