basic question/
Old Mar 3, 2002 | 09:59 AM
LightnigRod's Avatar
Question basic question/
the 2001 L has antilocking brakes all the way around ,does it not?
Old Mar 3, 2002 | 10:07 AM
Black2000L's Avatar
YES
Old Mar 3, 2002 | 10:19 AM
thanx.
Old Mar 3, 2002 | 02:01 PM
PWR_WHLS's Avatar
Interesting question. I wondered that too. I was told that they have four wheel anti lock brakes.. but then someone told me that it is a 3- channel system.
Which means it has individual sensors on the front two tires and one ensor for the rear- Apparently this is the common?
Can Anyone Confirm this?
I think this is the case because when I am on the brakes pretty hard and turning into my driveway at a slow speed, I can feel the pedal vibrate like the ABS kicked in...
John:
Old Mar 3, 2002 | 02:13 PM
SVT-AK-L01's Avatar
Yes this is true, your rear abs sensor is in the top center of your diff and picks up a signal from a exciter ring thats attached to the ring gear.
Old Mar 3, 2002 | 06:30 PM
PWR_WHLS's Avatar
Thumbs up
Very interesting info.
After further thought, would benefit very little from having independent sensors on the rear brakes, since the front would lock up first.
Again - thanks
Better to know too much than to not know at all.
BUT - Ignorance is truely BLISS
Old Mar 3, 2002 | 06:38 PM
PWR_WHLS's Avatar
Thumbs up
Again - thanks
Old Mar 3, 2002 | 07:30 PM
LIGHTNINROD's Avatar
John:
I don't think your brake pedal will vibrate from ABS at slow speeds--coming into your driveway. If it's vibrating at slow speeds, that might be a warped rotor but you have an 01 and it's too new to have warped rotors????????
Dan
Old Mar 3, 2002 | 08:22 PM
Adrenaline's Avatar
Post
I have felt the brake pedal vibrate (from the ABS) when stopping from what I consider to be reasonable speeds.... Not even slamming on the brakes or anything... It happened in my 2000 L, and does it on my 2001 L also...
Old Mar 3, 2002 | 10:23 PM
HyE_BoLt's Avatar
I also feel the brake pedal vibrate when coming to a stop with the wheel turned half way or fully turned. Whats up with that??
Old Mar 4, 2002 | 12:13 AM
KGM's Avatar
KGM
Have noticed the same thing. Wonder if the tires are sliding a little?
Old Mar 4, 2002 | 12:24 AM
QKSILVR's Avatar
Mine does that too when turning. Probably one tire slowing down too fast and causing sensor to show locking and activating brakes.
Old Mar 4, 2002 | 09:00 AM
PWR_WHLS's Avatar
QkSilver- Exactly what my conclusion was. Must be the rear brakes thinking 'pending lockup' and kicking in ABS.
Another interesting bit... If from a dead stop I manually shift from 1 to 2 and then have to brake real hard (while in 1st or 2nd), the brakes don't seem to respond nearly as well. Almost missed a turn when this happened :o
Good think this monster can handle
Anyone else experience this? Try it with no traffic around, you'll see what I"m saying.
p.s. I did have the rpm's around 2800-3500 <- I love the sound of the engine rumbling along
John
