On board Test program
Old Feb 17, 2002 | 01:21 AM
16w/Lightning's Avatar
Well I have a 2000 Lightning and most of you know that you can do that test program by turning the truck off and holding the odometer reset button down, then turning the truck to run, and holding it down till it reads test. Then you can flip through and read all the computer stuff. Well anyways I was at FUEL reading and was wondering what that means. I got 4 Lightnings to tell me their readings and they were all different. These readings were all While you were in PARK with the car running. the four readings were 92, 123, 190, 181. Well if anyh of you guys can tell us what this means and what good numbers are then thanks. Also the 181 and 190 were 2001 and the other two were 2000. Also if your fuel pump was to go out then would your check ENgine Light come on, would you be able to tell, and how could you tell?
Thanks and sorry for the long post
00 Silver L
Old Feb 17, 2002 | 01:27 AM
clonetek's Avatar
the FUEL reading is how much fuel you have in the tank in hexidecimal code.. i think thats what it is called.
if the fuel pump goes out, you'll prolly get a check engine light.. plus your truck wouldn't run..
hope this helps.
Old Feb 17, 2002 | 01:40 AM
RA6870's Avatar
Thanks a bunch I have been wondering the samething myself because it always has a different reading when I check it, and everybody elses reads different!! Would have never thought it was a fuel gauge!!! Guess I learned sometning new today!!!
Old Feb 17, 2002 | 02:07 AM
clonetek's Avatar
i believe its a value from 0 to 255
Old Feb 17, 2002 | 07:58 AM
SVT_FL's Avatar
Here is what the numbers mean: www.mustangworld.com/ourpics/News/99hec.htm
Old Feb 17, 2002 | 08:35 AM
kidtriton's Avatar
yea, and dont forget that the DTCs , or "codes" that it gives are for the instrument cluster ONLY. Working at a ford dealership, i have someone come in every so often telling me that their check engine light is on, but the only "code" in the truck is a oil pressure code, lol.
