C-Notch is DONE !!!
Old Feb 11, 2002 | 10:55 AM
SVTRobG's Avatar
Thumbs up C-Notch is DONE !!!
For more pics go to...http://nloc.net/forum/showthread.php?s=&threadid=11469
I'd recommand this mod to anyone with a Bell Tech 3/4 kit. It's very easy to do and each side took about 2 hours to complete ( using air tools ). No more bottoming out
Old Feb 11, 2002 | 12:45 PM
RTKILLA's Avatar
Rob, where did you get that C-notch from.
I think I would like to do that to prevent the bottoming out with my truck also.
Can that piece be welded on the frame?
Old Feb 11, 2002 | 12:55 PM
SVTRobG's Avatar
Joe,
The support is from Western Chassis. Excellent quality !!!
Here's why this brace should only be bolted on...
As you can see the C-Notch brace is twice as thick as the frame. Welding it would only weeken the frame. The notch was worth 3 more inches of travel.
Old Feb 11, 2002 | 01:19 PM
RTKILLA's Avatar
Hey rob, how much weight do you think that C-notch added.. HAHAHAHAHHAHA I'm so kidding. HEHEHEHEH
How much was that bad boy, its sound like the ticket for my truck. I can't tell you how many times I've bottomed out.
P.S. Did you get my E-mail. I want to ask you some things about your long tube headers, I'm getting some soon.
Old Feb 11, 2002 | 02:44 PM
JeffsLightning's Avatar
nevermind
Old Feb 11, 2002 | 03:04 PM
StrikesTwice's Avatar
Rob, loooks very good and solid! You're an inspiration to us! Now.. hand over those air tools!
Old Feb 11, 2002 | 03:10 PM
Ashenor's Avatar
Ah very nice i am lowering mine soon this spring. I was wanting to do a notch but was worried about how it would turn out. After seeing yours i am going to do it for sure now.
I have a friend that owns a custom show that really wants to do airbags .... So not sure i might end up with them this spring still.
Can you point me to a link or a # i can call to find out how much that is going to run me for one?
Old Feb 11, 2002 | 03:20 PM
D_Coburn's Avatar
I just ordered my Western Chassis C-Notches from Trucks Plus 704-483-7791 - @ $120 w/o shipping.
Old Feb 11, 2002 | 03:25 PM
Ashenor's Avatar
Ok thanks a lot.
Old Feb 11, 2002 | 03:34 PM
RTKILLA's Avatar
DAMN! that seems like allot of cash for just C notches. I bet I could have TRZ make them cheaper for us, and better too probably. they are suspension experts!
Old Feb 11, 2002 | 03:52 PM
Fast Gator's Avatar
Originally posted by SVTRobG
Joe,
Would/could you please explain why welding would weaken the frame, the frame isn't heat-treated
Old Feb 11, 2002 | 03:59 PM
DJY1's Avatar
SVTRobG,
Glad, I was some help to you for the part numbers. I forgot to tell you with the Bell Tech 4 inch drop, Western Chassis C-section on the rear. I did some more trimming with the Plasma cutter. I cut out some metal above the rear end and drive shaft to prevent the rear end and drive shaft from hitting the supports under the bed of the truck. I noticed someone did not trim his supports under his bed and his driveshaft broke. He has a silver Lightning. I found out by looking after drivng around and 1/4 mile racing the rear end and drive shaft can bottom out and cause damage with out trimming some of the supports under the bed.
djy
Old Feb 11, 2002 | 04:44 PM
SVTRobG's Avatar
Thumbs up
DJY,
I have a set of JDM traction bars that I still have to put on so I doubt I'll have any problems with axle wrap but I'll take your advice and check things out when I put the truck back down.
Fast Gator,
The reason I wouldn't weld that support is because that rear frame section is about an 1/8" thick and it's mild steel.
Joe,
The part # for the C-notch is 2129. The quality is top notch, the welds are real nice and it fits great. You also get Grade 8 hardware with the kit. You can't beat it for $ 130.00.
Old Feb 11, 2002 | 05:08 PM
RTKILLA's Avatar
DJY,
Fast Gator,
Joe,
Well I guess it would be worth it then with all the bolts to, those grade 8's are $$$$.
Hey rob, I got a plasma cutter at my office. you should have told me, you could have used it. I got two of then accutally!
Old Feb 11, 2002 | 05:10 PM
Ashenor's Avatar
DJY1 or RT, if you did it over lowering your trucks would you do it any different way?
I want to do mine as soon as the snow is gone, but just want to do it right. Hopefully will have my 20's by then and i like djy1's look.
