Who Has Installed H3 Fogllight Bulbs?????
Old Jan 21, 2002 | 05:28 AM
motoxracer21's Avatar
what wattage should be the limit?
THANKS man!
Old Jan 21, 2002 | 07:33 AM
Fast Gator's Avatar
I ran the 130W H-3's in my 99 with NO problems other than burned out bulbs! Now I was told that my 01 uses #9005 bulb in the foglamps
Old Jan 21, 2002 | 08:19 AM
SVT Bob's Avatar
Stay with the correct wattage bulbs. To much wattage will burn up the sockets. To much wattage on the fogs will put a brown spot on the lens or burn bulbs out faster from to much heat. I like the piaa,s a nice upgrade from stock. Not cheap I know. Bob.
Old Jan 21, 2002 | 11:17 AM
drcarrillo's Avatar
I am running Nokya 9005 Artic White bulbs rated at 100W in my 2001 fog lights. They put out a lot of slightly blue light and look great. I have been running these for about a month with no problems (knocking on wood).
Robert
Old Jan 21, 2002 | 07:40 PM
Ok, another question.... I just ordered the PIAA 9007 superwhite bulbs, and are those HIGH AND LOW beams, or do I have to order the low beams seperate? If so, whats the part number for them?
Old Jan 21, 2002 | 11:46 PM
BlownSVT2001's Avatar
The PIAA 9007 are both high and low beams. While you are at it, you should order the 9005's for the fogs. They made a big improvement in visibility in my truck.
Doug
Old Jan 22, 2002 | 01:02 AM
oh I did, trust me!
ordered em next day, so hopefully they'll be here tomorrow
anyone have pics of what this setup looks like??
Old Feb 20, 2002 | 08:53 PM
RA6870's Avatar
So the 9007 are for the headlights and the 9005 are for the fog lights?? can you use a 100 watt bulb in the fog lights without burning the plastic dome??
Old Feb 21, 2002 | 09:41 AM
snoopy's Avatar
fwiw: the 02s use 9145 bulbs (aka "H10") at what appears to be 42 watts.
I don't know what bulb/wattage the 99-00s use, but the only H3s I've ever seen are 37W, 55W, and 100W. A lot of OEM fog lights use 37W bulbs, which explains why they are almost useless in real fog.
If the earlier models use a 55W H3, then perhaps they switched to a 42W H10 in order to reduce heat and cracking. If the newer lenses still crack, then perhaps we could use a 37W H10. That is, if one can be found. They'll look nice but won't do much if you really need them.
