Help with wiring
Old Nov 29, 2001 | 12:58 PM
soap's Avatar
Question Help with wiring
I have read before stuff like...."I tapped into the #4 pin"
My question is how the hell do you know what each pin is used for and what each pin number is.
Do you guys have a manual or something???
--Joe
Old Nov 29, 2001 | 01:11 PM
2_FAST4U's Avatar
Well, All electronics and stuff that uses connecters has diagrams for pin location and purpose.
If you are asking this question about the A/F gauge hookup!!! I wouldn't recommend wiring that way. You can run the risk of shorting out other things.
I wired mine directly in the O2 sensor. The black wire is your signal!!
Old Nov 29, 2001 | 05:30 PM
soap's Avatar
2_FAST4U !!!!!!!!!
That is exactly why I was asking.......thanks for the help.
The only reason I didn't want to wire it into the O2 sensor is it says on Auto Meter's directions not to do that b/c some O2 sensors have "shielded" wires. Also it doesn't matter what O2 sensor I tap into does it????
Thanks again......Joe
Old Nov 30, 2001 | 07:38 AM
soap's Avatar
Unhappy help...
Anyone????????
Old Nov 30, 2001 | 08:17 AM
2_FAST4U's Avatar
Joe,
You can access the signal wire for the O2 sensor very easily!!
I used a incline crimp to splice the two wires together. Trust me....you will want to do it like this....if you splice a pin you run the risk of shorting the computer and then you are deep chit!!!
Oh, the drivers side O2 sensor is the one you want to splice.
Old Nov 30, 2001 | 09:03 AM
jarmstro's Avatar
AF Guage
I agree with 2_FAST4U about splicing into the O2 sensor. If things don't go right pull the sensor and replace it.
The black wire is correct and I used the back sensor drivers side.
Old Nov 30, 2001 | 09:28 AM
nminor's Avatar
Here's a link that I used to hook up my guage. Hope this helps-Neil
http://www.svtperformance.com/forums...r%2Ffuel+guage
