Gear heads- ft/lb-in/lb conversion question
Old Oct 18, 2001 | 08:42 PM
99WhiteBeast's Avatar
Question Gear heads- ft/lb-in/lb conversion question
I need to torque bolts on tranny accumlator to 80-100 in/lbs but only have a foot lbs torque wrench.
Does anyone know how to convert or tell me the foot lbs?
Thanks!
Old Oct 18, 2001 | 08:46 PM
Autothrottle's Avatar
There are 12" in a foot.......
So 80 inch pounds would be 6.6 ft lbs
and 100 inch lbs would be 8.3 ft lbs.
Old Oct 18, 2001 | 08:59 PM
I thought there would be some type of conversion factor.
:o
Old Oct 18, 2001 | 11:34 PM
Spike Engineering's Avatar
The conversion factor is:
Inches to feet: divide the number by 12. For instance, the truck bed on the Lightning is wide enough to hold a sheet of plywood which is 48 inches wide. If you want to convert that to feet, divide it by 12 or multiply it by 1/12 (48 inches x 1 ft/12 inches) and you get 4 feet.
Feet to inches: multiply the number by 12. Using the example above, if the plywood is 4 ft wide, it's 4 ft x 12 inches/ft = 48 inches.
Using your example:
84 in-lbs x 1 ft/12in = 7 ft-lbs (you're just dividing by 12)
96 in-lb x 1 ft/12in = 8 ft-lbs
spike
Old Oct 19, 2001 | 12:23 AM
captainoblivious's Avatar
just use it as an excuse to go out and buy an in-lbs torque wrench. Thats what I did and know I have both
Old Oct 19, 2001 | 12:37 AM
It would be better to have the inch-lb torque wrench because of the precision (not accuracy) of the dial.
Spike
Old Oct 19, 2001 | 08:20 AM
pvteye's Avatar
1 Inch-Pounds = 0.083333 Foot-Pounds
1 Foot-Pounds = 12 Inch-Pounds
http://www.onlineconversion.com/torque.htm
rex
Old Oct 20, 2001 | 12:11 AM
Factory_Tech's Avatar
And I spent 16 years in college to learn all this...
G
