How much boost can the engine take?
Old Oct 5, 2001 | 05:52 PM
  #31
RTKILLA's Avatar
Do you guys want a simple solution to your boost problems.
BUY A NOVI 2000 BLOWER!!!!!!!!!!!!!
30 PSI is all you'll ever need.
Old Oct 6, 2001 | 11:26 AM
  #32
Spiro99SVT's Avatar
Originally posted by MRBBQMAN
Here's the straight scoop:
the new eaton M166 will be a 03 model exclusive to GM's new 8.1L Silverado SS496. it is rumored to be "Faster than Spiro on a quick clock" whatever that means. Ford is going to counter with, the 03 Lightning twin-turbo awd V-10. so keep your 01's and 02's in pristine condition, because your going to be getting rid of them soon, and remember,, a rumor has to start somewhere
LOL....leave it to the BBQMAN to start the rumor Hey..what does that mean?
Old Oct 6, 2001 | 03:06 PM
  #33
Georgia_Moon's Avatar
Hey everyone,
Since I work very close to the Eaton Supercharger plant here in
Athens Ga....could probably find out the actual facts about this blower....some time ago my past 2000 L was on display on their front lawn....saw their R&D facilities etc....extremely nice people...
in fact....if any of you had some questions for them, might be able to ask the plant engineers....let me know.
Old Oct 30, 2001 | 06:42 PM
  #34
superchargers1's Avatar
Hey
Hey Georgia Moon,
Do you work at ABB? I think we pass each other every morning..
Drop me a line....
SC1
Old Oct 30, 2001 | 07:06 PM
  #35
DB's Avatar
DB
superchargers1,
What's your take on the boost level and overspinning with our M112's? Tons of folks using 2-4# larger lower blower pulleys along with 1-2# uppers with seemingly no ill effects. Are we going to see more trashed blowers and motors longer-term?
Old Oct 30, 2001 | 07:10 PM
  #36
Struck in AZ's Avatar
Lightbulb
Just spoke to Jim at JDM this afternoon and the scoop I got from him was that the new blower is currently being tested on one of their trucks. I called him to see if the stuff I currently have (4 lb. pulley, 1 lb. upper, throttle body, chip, etc.) will work with the new blower. Jim claims that the blower in a stock setup will provide 15-16 lbs. of boost. He also said that if I were to use any pulley to go with the 2 lb. lower or 1 lb. upper but not both. He feels (and Sal may verify this) that at 18-20 lbs. of boost these things become nice expensive grenades with the rods being the "pin." Jim's previous motor lunched itself because of a bad rod and it appears that everyone else agrees that the rods are the current "weak link" in these engines. So it appears that 18-20 lbs. may be the maximum boost before having to rebuild the bottom-end using higher quality (stronger) parts.
Dan
Old Oct 30, 2001 | 08:01 PM
  #37
1BADTK's Avatar
Re: Hey
Originally posted by superchargers1
Hey Georgia Moon,
I am one of the Engineers at Eaton. Do you work at ABB? I think we pass each other every morning..
Drop me a line....
SC1
Can you enlighten us any on the new blower Jim is testing for you guys? Is it or will it be a retor fit unit for the 99-01 Lightnings and will it be sold by Eaton through distributors or direct?
Old Oct 31, 2001 | 01:49 PM
  #38
1BADTK's Avatar
Supercharger1
Well if it's that big of a secret, we really do want some kind of confirmation. HELLO?
Does Eaton have you on "Hush Hush" mode?
Old Nov 1, 2001 | 09:18 PM
  #39
1BADTK's Avatar
Hum?
Maybe he doesn't work for Eaton after all, or school got to tough to finish so the Engineer Degree is still missing. If you can't say anything then just say so, but don't jump in a forum about a new design on a Eaton SC for Lightnings and cry "I work there" and then leave us in the dark.
