X-Plan...... HOW????
Old Sep 28, 2001 | 04:39 PM
beefcake's Avatar
OK, you asked!
Performance Mods:
Lidio Tuned, Speed Pro Controlled, Forged 4.6 w/Manley Rods & JE Pistons, Ported Stock Heads, Custom Long Tubes, Custom X Pipe, Custom 3” Exhaust, 97 Tank, Export Filler Neck, Cartech Pickup, Bosch External Pump, Kenne Belle Boost A Pump, #8 Feed Lines, 99 Fuel Rails Converted to Return Style, 55lb/hr Injectors, Cartech Regulator, #6 Return Lines, MSD DIS-4 Ignition, Autologic Computer Chip, Vortech SC Trim w/Impeller Upgrade to S trim, 2.87” Pulley, SHM/Alternative Auto Custom 8 Rib Pulleys, SHM Air to Air Intercooler, Anderson Ford Power Pipe, K&N Air Filter, 92' GT Housing w/31 Spline Superior Axles, Racing Wheel Studs, FMS 4.30’s, Detroit Locker, FMS Aluminum Drive Shaft, Drive Shaft Loop, Bullet Proof Ford 4R70W Overdrive Transmission w/ Stallion Locking Torque Converter & Baumann Engineering Baumannator TCS(Transmission Control System), KB Oil Pan, KB Windage Tray, KB Sub Frame Connectors, Ground Pounder Coil Overs, Ground Pounder A Arms, Ground Pounder Tubular K, Tokico 5-Way Adjustable Drag Struts, Moroso Rear Trick Drag Springs, Pinion Snubber, Ground Pounder Upper Control Arms, South Side Lower Control Arms, Maximum Motorsports 6 Point Roll Bar w/Swing Outs, Autometer Phantom Boost & Fuel Pressure Gauges, MSD Shift Light
Appearance Mods:
Forgeline RS Wheels 17x11 Rear with 315's and 17x9 1/2 Front with 275's, Weld Draglites for the Strip w/skinnies and M/T ET Drag 28”, Steeda Cobra R Hood, Steeda Rear Wing, Saleen Side Scoops, 5 Point Harness, Corbeau Targa RS Seats, Mark Lutton Rear Seat Delete Kit, Tinted Windows, MGW LTD Headlight ****, Door Pins, Cigarette Lighter, E-Brake Handle, AC *****, Fuel Door, Cobra Grill Emblem, Steeda Pedal Covers,
Old Sep 29, 2001 | 06:11 AM
TowsAmustang's Avatar
Beefs car is baddazzz
Beef isnt a bS'er. His car is badazz. It was a cover car for MM&FF a few months back.
You still selling it beef?
Ill give you 20K for it
Old Oct 1, 2001 | 09:35 PM
GMNightmare's Avatar
U looking For a trade Beef?
Or u looking to sell Outright.
Old Oct 1, 2001 | 10:46 PM
beefcake's Avatar
already sold,
deposit received today
Old Oct 2, 2001 | 02:10 AM
DAMN
o well i tried.
Looks like ill have to build my Big Thumper LS1 then.
