Clear Tails
Old Aug 24, 2001 | 03:45 PM
ally69's Avatar
Clear Tails
I did search but got nothing.
I just got my 01 clear tails from dealer. Do they bolt right in on a 2000? Same number of bulbs and do I need different bulbs
Old Aug 24, 2001 | 03:49 PM
Silver-Bolt's Avatar
They do bolt right in, however you will need shorter screws or a stack of washers. The 00 tail light screws are too long and will poke through to the inside if you don't cut them off or stack up some washer. Bulb connection are the same. Plug and play.
Old Aug 24, 2001 | 04:12 PM
ally69's Avatar
Anyone know how much shorter? Thanks for the response.
Old Aug 24, 2001 | 04:25 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Talking
ally,
just test fit the screws and add washers as needed.
**DO NOT** go too deep when you're screwing, you might cause undue pain or something......
Old Aug 24, 2001 | 06:06 PM
mrelmtow's Avatar
Just shorten the screws up to the start of the threads and use a washer 1/8" thick. It worked for me!
Mike
