blown up lightning need advice!
Old Oct 6, 2012 | 11:08 PM
wht00lightning's Avatar
So I just bought a 2000 lightning thursday night test drove before I bought it had an engine light but they cleared it before I left the lot...no they did not tell me the code. Engine sounded great charger sounded great 170,000km drove it 2 hours home cruise control 110kph put my foot into her a couple times for a couple hard pulls. VERY NEXT MORNING got up for work half way there truck was up to operating temp stepped into her n lost power without warning put in neutral shut off engine and tried to restart. Wouldn't start oil huffing out the valve cover breather and I'm pretty sure I heard the piston come clanging out the exhaust
needless to say the dealer I bought it from paid for a flat bed and are fixing the motor for free
As far as I can see its got an airaid intake n a loud as f*ck exhaust no idea what brand
Should I be scared this motor is going to spit out another piston/motor?
Old Oct 8, 2012 | 06:30 PM
slammediam's Avatar
Was you going WOT with it in overdrive?Also what was the temp outside?
Old Oct 8, 2012 | 07:07 PM
1LethalSVT's Avatar
Like slammediam asked WOT in OD? If so those are a no no. Also look at the bottom SC pulley and measure it from lip to lip. It may have been upgraded and the tune for that pulley was erased. If that's the case, yes you will blow the new motor unless you get it tuned by a tuner.
Old Oct 9, 2012 | 02:24 PM
I don't think I was in OD I think it was in 3rd...temp was maybe between 4 and 8 degrees. No idea about the pully ill measure when I get it back from the shop..ur talking the one off the crank right? Finally here goes the n00b question y can't u go WOT in OD...anything else I should be warned about not doin?
Old Oct 9, 2012 | 10:42 PM
slammediam's Avatar
Anytime you go WOT,make sure OD is turned off....When it down shifts,it puts stress on the bottom end...The bottom end is a weak point..And double check the pulley(lower crank).If you have a pulley find out the measurements...If you live where it gets cold and you have a lower pulley,stock block wont like it either
Old Oct 10, 2012 | 12:02 AM
So basically when it down shifts any gear is dangerous or just OD to 3rd or 2nd. Also if that crank pulley is different would my Ford dealer be able to tune it or no? I live in northern Canada it gets to -40 here lol...lastly does anyone make stronger rods for this bad boy? Saw the jdm performance ones but weren't sure if they were better or not
Old Oct 10, 2012 | 07:14 AM
1LethalSVT's Avatar
JDM, JLP, and a bunch of others build stronger motors for the L's. Now here's another issue that could have been part of the reason you blew the motor. If the bottom pulley has been changed and the stock tune put in. At those temps (4 to 6 degrees) you could have maxed the mass air flow meter. Your best bet at finding the reason or at least eliminating some reason is by getting a picture of that bottom pulley and posting it here. If not at least the belt part number if it's readable on the SC belt.
Old Oct 10, 2012 | 03:53 PM
I'm calling the shop today see what they have found...I can't see the pulley being changed because with the few pulls I did the day before it should have blown up then....will give u guys an update later tonight
Old Oct 11, 2012 | 12:13 AM
Ok so I called the dealer they haven't started working on it yet but the mechanic looked at it quick n said it needs a complete engine(no sh*t I think we all new that). Anyways I have to call back Friday see what is happening
Old Oct 12, 2012 | 06:03 PM
So I called the dealer they are trying to find me an engine....can't they just call Ford and order one? Arent these engines stock piled in a warehouse?
Old Oct 12, 2012 | 07:11 PM
How can I get the engine number without actually having the truck?
Old Oct 13, 2012 | 02:28 PM
Bill Bell's Avatar
PM sent!
Old Oct 13, 2012 | 05:42 PM
Thanks bill appreciate it
Old Oct 16, 2012 | 11:18 PM
Ok finally got an update on my lightning they are sending it to an engine rebuilder to get rebuilt...anything to worry about
Old Oct 16, 2012 | 11:31 PM
1997 lariat 4.6's Avatar
spit plugs, or use of stock rods... other than that i dont know much about l motors, but that is my general knowledge...
