blown up lightning need advice!
Old Oct 29, 2012 | 10:53 PM
  #31
wht00lightning's Avatar
sine they are tearing it down, at least have 'em swap out the stock rods for stronger ones (unless they get you another longblock)
Ya they went with a long block. They said they r gunna take it to a dyno tuner also
Old Oct 29, 2012 | 11:32 PM
  #32
XXRJXX's Avatar
sounds funny, if the motor blew and rod went or piston melted could have caused major damage to the head if not both.. i would be leary about what is getting put in ur truck.. i would want to see it done part by part so u knew what was being installed.. i think u can even buy aluminator blocks now for like 3500.. as well before u do any driving or break in i would wanna have the tune either looked at or re done.. should def look into a mafia tho
Old Oct 30, 2012 | 07:56 AM
  #33
Veteran: Army
the almininator is a 32 valve 4.6 and won't work with the 5.4 Eaton supercharger assembly
and yeah he needs a MAF or MAFia
Old Oct 30, 2012 | 09:33 AM
  #34
What is the best MAF u can buy? And do I REALLY need a MAF if I'm getting the tune done? And if I did get it would I not have to retune it
Old Oct 30, 2012 | 10:36 AM
  #35
Veteran: Army
talk to your tuner, my personal opinion is the SCT BA2400 or SCT BA2800 (those are the old ones that can be used in a stock housing, but since they had some issues with Ford they offer a BA2600 and BA3000 now that come in a 90mm housing with a different bolt pattern than the stock electornics)
Old Oct 30, 2012 | 11:50 AM
  #36
XXRJXX's Avatar
who said anything about buying a long block aluminator? buy aluminator block whick is good for about 600rwhp and use 5.4 heads.. kindergarten stuff..
Old Oct 31, 2012 | 10:05 AM
  #37
Veteran: Army
STOP GIVING BAD ADVICE, stop being a tool and learn before you cost someone a lot of money due nto your ignorance
you are suggesting use the 5.4 2 valve heads on a 4.6 block then what is he going to do for the lower intake assembly????
for anyone who finds this thread, feel free to ignore any "advice" / "suggestions" made by XXRJXX
a 5.4 and 4.6 blpock difference is like the 302 and 351w block difference and due to deck height the intake manifolds will not interchange rendering this almuniator "suggestion" utterly useless if a Lightning owner woishes to retain the stock lower intake manifold...
Old Oct 31, 2012 | 10:10 AM
  #38
Was on SCT website n I'm gunna go with the BA3000 but they say it bolts right up. Do I need it tuned again if I put this in?
Old Oct 31, 2012 | 02:27 PM
  #39
JollyGiant's Avatar
The BA3000 is probably overkill unless you are planning some serious modding. The BA 2600 is rated for 400-700 RWHP. You will definately need a tune with any MAF change you make.
Old Oct 31, 2012 | 04:01 PM
  #40
I'll see what the price difference is first but I might as well go with the better one if its about the same
Old Oct 31, 2012 | 09:11 PM
  #41
Veteran: Army
bigger isn't always "better", this is where you need to talk to your tuner, not all tuners are created equal and many don't like to tune the larger MAF's when they aren't needed
Old Nov 1, 2012 | 09:35 PM
  #42
I wanna do pulleys, whipple charger, machine the heads or buy better ones, obv build the block and I'm thinkin that might be it
Old Nov 2, 2012 | 02:21 PM
  #43
JollyGiant's Avatar
I'm running a Whipple with pulleys. No head work and a stock block but a BA 2600 is more than adequate for my setup. Like tarajerame said, bigger is not always better and could lead to tuning problems. The MAF should be sized based on your expected airflow, not price.
Old Nov 3, 2012 | 10:55 AM
  #44
Well I guess ill go with the 2600 for now. Is there a big difference between kennebell n whipple chargers? And with ur pulleys how does the charger stand up? I know they say the charger spins to fast n grenades but it that true for all superchargers or just the eaton charger?
Old Nov 3, 2012 | 02:01 PM
  #45
JollyGiant's Avatar
I started with a ported Eaton, switched to a Kennebell and then to a Whipple. The KB and Whipple are very similar when it comes to HP increases. I like the sound of the KB more than the Whipple but I got better times at the track with the Whipple with both running the same boost. I would say it's pretty much a toss-up between the KB and the Whipple so just look for a good deal.
